AVS › AVS Forum › Audio › DIY Speakers and Subs › Vote: Which four 18 or 24 inch drivers for sealed enclosures and why?
Vote: Which four 18 or 24 inch drivers for sealed enclosures and why? - Page 14
Poll Results: Which four 18 or 24 inch drivers?
  • 23% (17)
    A. SI-24
  • 26% (19)
    B. TC Sounds LMS 5400 Ultra
  • 4% (3)
    C. TC Sounds Pro 5100
  • 17% (13)
    D. UXL-18
  • 13% (10)
    E. Dayton Ultimax18
  • 10% (8)
    F. SI-18
  • 4% (3)
    G. Other
73 Total Votes
post #391 of 408
Originally Posted by bass addict View Post
I'm going out on a limb, but I'm thinking the concern wasn't in regards to the driver.
I want to implement one just to be able to say I have a 24" woofer. biggrin.gif
post #392 of 408
Originally Posted by steve nn View Post
post #393 of 408
Seriously, I promise that's the last time I'll do that pic. It was a hooter the first time around though. LOL
post #394 of 408
That one was definitely a classic lol.
I was going to do a judge Dredd no thumbs up picture but couldn't find a good one in time. biggrin.gif
post #395 of 408
Originally Posted by beastaudio View Post
Not sure what issues you are concerned with, but I had one of those 24's for a long weekend on loan from SI and the build quality on that woofer was top-notch. I wouldn't hesitate to pop a few in my space if I still had room to do so biggrin.gif
There are a few guys that keep talking about these "concerns" , but nobody will say what. I know they aren't to do with the build quality of the woofers it's just weird that no one will come out and say why they have such strong feelings against Si. I think it would be helpful for others to know just what is meant.
In any event, hope you enjoy what you decided on and look forward to seeing your impressions
post #396 of 408
post #397 of 408
post #398 of 408
So the SI 24 has 7.7 liters of displacement (1 way xmax) at the cost of $800 or $104/liter
The Si 18 has 2.7 liters of displacement (1way xmax) at the cost of $162 or $85/liter
I know that D4s aren't available, so think back to when they were, but for less money, why not get 3x Si18 and wire D4 in series/ then parallel them for 2.7 ohms, or even 4x and series parallel D2s for 4 ohms (which are available)
Still cheaper, more displacement, I think similar sealed volumes and less thermal compression on the VCs.
Is there something special about the 24's vs the 18s (or 15's for that matter) besides shear size (which, I'll grant you, is pretty ****ing amazing and awe inspiring lol)
post #399 of 408
So yeah, they're just bigger than a smaller driver. What makes an 18" so cool? Cuz it's bigger than a 15" driver. tongue.gif More displacement from a single motor. Whether that is good or bad to you is up to..... umm..... you. wink.gif
post #400 of 408
That's the way I went but wired for less power. Dual trio of SI's wired for a 6 ohm final load. Less excursion while allowing them to motor along in my small 2,200 cf room. smile.gif
post #401 of 408
usually, it is the case that larger drivers offer better displacement value. That doesn't seem to be the case here. The multiple 18's are better value, suffer less thermal compression, and would help with evening out room modes. I can see a 24 winning out if you want a single in a smaller cube where you don't have the baffle surface area to work with. But if you want multiple 24's or can accommodate the surface area, I don't see the point.
post #402 of 408
I believe Nick has said that the price is going up on the SI 24 to $1000, so soon it'll be $130/liter.
post #403 of 408
Yup. Agreed. You aren't going to see a ton of +2 24" installs. Most DIY'ers are on a budget.
Even my crazy system represents an insane value/performance ratio. I'd even wager that it has the highest value/performance ratio to anything else on AVS.
post #404 of 408
post #405 of 408
post #406 of 408
post #407 of 408
Ahahaha! No.
post #408 of 408
Ahahaha! No.
lol......
