AVS › AVS Forum › Audio › Speakers › Help With my Selection
post #1 of 24
1--Jamo S 426 HCS 3 WENGE 5-Piece Home Theater System
2--Polk Audio TSi300 5.1 Home Theater Speaker Package
3--Definitive Technology Pro Cinema 800 System Black
I using the Yamaha RX-A730
Please help me pick one...
post #2 of 24
What is your budget?
What is the size of your room?
What are your listening preferences?
post #3 of 24
I have a big living room. .
Mostly for movies..
About $800 or more..
post #4 of 24
Mostly for movies..
What does "big" or "800 or more" mean?
post #5 of 24
post #6 of 24
Originally Posted by mark62 View Post
The Jamo's are not very good I got them for $129 and returned them...
these are another option..
http://www.htd.com/Products/level-two-speakers
http://www.htd.com/Products/level-three-speakers
sub...
http://www.parts-express.com/dayton-audio-sub-1200-12-120-watt-powered-subwoofer--300-629 2 of these
or
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1391900170&sr=1-1&keywords=bic+subwoofer
Are these sub better than the Klipsch 350 subwoofer?
http://www.svsound.com/subwoofers/ported-box/PB-1000#.Uva15pB6OGQ
all of these subs are better than the ones in the packages...
post #7 of 24
Yes they are better than the Klipsch 350 subwoofer by a long shot.
post #8 of 24
post #9 of 24
18×18 living room.
Bought the klipsch 350 subwoofer $80..
post #10 of 24
18×18 living room.
That sub is not really good enough for that size room, however it may be enough for you.....
post #11 of 24
Are you suggesting I should get the one on parts express.com for $129
What about TSI300 floorstand?
post #12 of 24
Yes the Sub-1200 or the Sub-1000 would be better.. preferably 2 of them, maybe add one at a later date...
IMO there are better speakers than the TSi at that price point. What price can you get them for?
The HTD Level Twos for example are better...
post #13 of 24
The have the pair of TSI300 for $160..
I will get one of those sub..
post #14 of 24
I didn't know you already had the Polks, what is your question regarding those?
post #15 of 24
I am trying to buy the polk..
post #16 of 24
post #17 of 24
Need a good center channel under $150..
Any help.
post #18 of 24
Any help.
You should always get a center that matches your mains...
post #19 of 24
Does it matter if the 4 surround are different from center and the two front..
The is going to be my setup:
A Pair of Polk Tsi300B for the Front
A matching center if I found one
And 4 Definitive Technology Procinema 800 for the surround.
post #20 of 24
post #21 of 24
The Matching center to the TSi300's is the Polk CS10 and they are widely available in the USA just follow the links above.
Surrounds don't have to match the front 3 but without matching front 3 you are really missing out. Thats why you should get the CS10
post #22 of 24
Thanks Guys..
How good is this Dayton Sub 1200, I see it has a lot good reviews.
Are reviews a marketing stunt or is it that good?
post #23 of 24
Thanks Guys..
For the price there is nothing better. Its a good subwoofer for its money. Its that good. Spending more money would get you a better subwoofer but that is how it goes.
You could also try the Lava LSP12, email them that you are a AVS Forum user with your user name and they might give you an additional 15% off the already low price of $170
post #24 of 24
Mostly for movies..
There is a Hsu 5.1 package for a hair over $1000:
http://hsuresearch.com/products/value1pkg.html
  Back to Forum: Speakers
