AVS › AVS Forum › Audio › DIY Speakers and Subs › MartySub Flatpacks
MartySub Flatpacks - Page 14
post #391 of 2481
Originally Posted by chalugadp View Post
Hp at 20. I have peq at 20hz 3dbs .8q
Can you tell me which hp filter you are using?
Oh and any other hardware that you recommend for this....
post #392 of 2481
Order went thru for 2x D4s. You guys are killin' me. Oh well, if I run out of money I can always make Headphones out of them haha. Like Data-Bass said - It would work well as a Woofer in a 3-way crossed over @ 350-400Hz.
post #393 of 2481
It will depend on your room and your mains. I like 48db butterworth , but play around with a few and see what you like.
Hardware .... not sure what you mean.
post #394 of 2481
12db butterworth aka second order is fine in most cases.
what some folks do is center that one right on the tuning frequency of the cab, then put another filter of 2-3db of equalization on to bring spl back up a hair right around the tuning frequency. this is usually ok because the driver isn't moving very much right around there (so long as power output is kept reasonable, ported cabs hit max power right on the cab's tuning frequency).
post #395 of 2481
Nice !
Watching Prometheus right now with one. Can't imagine two.
I just placed my order for two D4's as well! I am super pumped to join this martyparty!!!
post #396 of 2481
Ok I have watched parts of five movies and listened to music for about three hours. These observations are subjective but since the cube is working under the same setup as full marty and in virtually the same location, at the same volume level (-5 from reference for movies, -15 to -20 for music). I am going to use a little of the flowery language so don't beat me up. For music I really prefer the cube. It seems to handle difficult passages of music with tighter smoother bass. For example Black Eyed Peas Missing you is a song with lots of different octaves mixing together. While I was listening to that song I ended up toe tapping and closing my eyes and just grooving to the beat. I don't do that very often. Midbass is definitely punchier with the kick drum being felt more in your chest.
The dampening I used for both was the same amount, plywood the same, both heavily braced. For movies gunshots, punches, swords slamming into walls is better with the cube. Their is the drop off of the lowest bass which I can hear as well.
20hz to about 28hz is definitely better with full marty. I think the second cube with the uxl18 driver will take care of that weakness. My room is 3000sqft in size. overall I am very happy. When my second cube is hooked up i will give you more impressions.
On a side note I really enjoyed our build night with Jbrown and Warren. It was cool to talk speaker stuff with someone who really cares about it. Friends and the wife just nod their head when I am telling them about my system. Going to get about 5 sheets of mdf on monday.
post #397 of 2481
This will be my first build. Didn't know if I needed a xover, feet, what wire connections you recommend, etc. Just making sure I am covering all my bases.
post #398 of 2481
wink.gif You mean 3000 cubic feet? 3000sqft is bigger than my house!
Sounds like just what the Dr ordered!!!
post #399 of 2481
Best thing to do is post a build thread and then you get answers from several sources. I'm only a midlevel guy here. Don't have the knowledge of the big boys. I'm using inuke3000 dsp amp , speakon cables from monoprice , dampening from pe.
post #400 of 2481
That is soooo good to hear. I just love tight, articulate bass. Just curious; will you be keeping your full marty in the mix or will you be retiring it?
post #401 of 2481
Sorry for my ignorance here but do subs need a crossover? Or is it simply wire the sub to the speakon input and you are done?
post #402 of 2481
Lol... I know you'd probably rather be spending your time doing something else on a Thursday night then help with building my sub, but it was enjoyable at the same time because like you said its fun to shoot the sh*t with people that have the same interest in this hobby. All my buddies just think I'm crazy...lol
Let me know if you want some help on Monday cutting up that MDF, I'm free after 4:30.
post #403 of 2481
Yes subs need xover. The inuke3000dsp does that for you. Sounds like you would benefit from reading this
http://www.audioholics.com/subwoofer-setup
Some good info to get you started.
post #404 of 2481
Will be ok next week.. will need some help the week after.
Something to think about is the possibility of you building two monster subs and two cubes. That way you would have great low bass and great midbass . Best of both. cool.gif
post #405 of 2481
You think the cube will have more mid bass then the boxes I'm building? I don't remember what the graph was show for the cube from 50-100hz.
Here's the graph for the cabinet we just build for my sub.
post #406 of 2481
Thanks for the link. I will read up on this. On my initial search through there I didn't see a step by step of how to build a sub. Does anyone know of a step by step play book of building a sub? What you need, diagrams, etc. ? Sorry for the noob questions.
post #407 of 2481
Your box is basically the same as full marty. Same cuft. On Ltd's graph cube has couple more dbs then full marty in 50-70 range. That's how my measurements were. I think from 15-30z bigger box is better. 50-70hz cube is better . Why not have best of both. Either way you can't go wrong
post #408 of 2481
Do you have the graph you could post? Too many pages to go looking for it!....lol
post #409 of 2481
I will be creating a build booklet for the martycube . Be doing it probably next weekend .
Just search build threads on here , spend an hour reading a few and you will get up to speed
post #410 of 2481
Green is your box , black the cube. This is with si18 driver. Uxl18 would be I am assuming equally higher for both. Red line is uxl18 in cube.
post #411 of 2481
The green graph on this is different then the one John gave me for the build on my cabinets.
post #412 of 2481
yours is tuned a little lower and uses the uxl driver so the response is a little different.
post #413 of 2481
At 20hz, the uxl-18 driver should have a 5db gain over the SI driver in the Marty cube!!! The uxl-18 will be a monster in the Marty cube as you will get a little more extension as well as way higher spl!! Many thanks to ltd02 for this great design...
post #414 of 2481
From looking at those graphs the cube will only have about 1-1.5dB more mid bass then my cabinet and from about 80hz and up the are the same. But down low my cabinet has a pretty good advantage over the cube. I'm building my setup for movies so I think I'll just stick to the original plan of four large cabinets.
post #415 of 2481
If his is tuned a little lower then wouldn't he be giving up a little in the 40-70hz range to gain in the 15-25hz ? Not sure just asking ... Still have lots to learn for me. smile.gif
post #416 of 2481
I will be able to compare once I get my driver from Mark. Plan on having the 2nd cube box done by Wednesday. Then have to start building for others cool.gif
post #417 of 2481
So you will running 2 different subs? Can't wait to see and hear the results!
post #418 of 2481
Both cubes , one with uxl18 and one with si18 . Can't at this point spend another 400 for another uxl. Want to upgrade my mains , and get a oppo. Eventually might replace si18 with another uxl18 if needed.
post #419 of 2481
I am going off your word and went with the SI 18s. I want my subs to be matched so I ordered 2. Seemed like a great price. I got 2 subs, and will get an amp for less than a vtf15 that I was originally looking at!!! Oh and why isn't this the donnycube? We haven't heard from martycool in a while. Guess he is too busy enjoying his creation....
post #420 of 2481
Your two subs will demolish the hsu. By about 6-12 dbs depending upon hz. Should be named johnnycube ! biggrin.gif
