AVS › AVS Forum › Audio › Speakers › Distance for flat panel speakers from TV
post #1 of 7
Is there a preferred distance for the L/R flat panel speakers away from a tv? How about the center?
post #2 of 7
It's considered ideal for the L/R and LP to constitute an equilateral triangle. Put the center above or below the screen.
post #3 of 7
LP? Little help. Newbie here.
post #4 of 7
post #5 of 7
Listening position.
post #6 of 7
Just what I needed. I always thought the look of right next to the tv was weird. Thanks.
post #7 of 7
A lot of people put the Flat Panel speakers close, due to placement restrictions,
due to room set-up, or TV placement (fire place).
However, if you have room to spread them, then do it.
  Back to Forum: Speakers
