AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Need help replacing my amp
post #1 of 7
I have a Dayton sub that just had the amp die. What amp can I get to replace the dead one?
http://www.parts-express.com/dayton-audio-10-100-watt-powered-subwoofer--300-632
post #2 of 7
Just look at the PE site for a plate amp that is about the same size (exactly same size is better) and about the same power. A drop in replacement is very straightforward.
If you cannot get an exact size match, you might consider a new subwoofer because cutting-and-pasting to get a new plate amp to fit can be a very big hassle.
post #3 of 7
If you cannot get an exact size match, you might consider a new subwoofer ...
+1. $120 (incl. shipping) will get you into a brand-new, well-rated Dayton SUB-1000.
post #4 of 7
I wouldn't waste my time it. Perhaps you could convert it to passive sub, won't cost you anything if you have a amp lying around.
post #5 of 7
I'm starting to lean this direction.
post #6 of 7
Is a passive sub one that uses an external amp?
post #7 of 7
Yes.
Enviado de meu GT-I9505 usando Tapatalk
