AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › total screen not showing up on UN60F7100
post #1 of 3
Something odd started happening on my UN60F7100.  I think it just started. I am not sure if it is the TV or Suddenlink/PACE cable box.
I can't see the entire screen.  See the picture. The TNT is shopped off.  On many channels that overlay text/graphics, it seems to be truncated.
I have tried all Picture sizes.
See the TNT on bottom right is cut off.
post #2 of 3
Definitely looks like the zoom picture size option is enabled.
Did you try to see if this happens with blu-ray or DVD movies?
If itt doesn't then it's your cable box at fault.
post #3 of 3
Yes, my bad.  I unplugged the suddenlink pace STB and reconnected.  All is good now.  Should have tried that first.   Thanks.
