AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Mobile, AL / Panama City, FL - HDTV
Mobile, AL / Panama City, FL - HDTV - Page 2
post #31 of 4065
Sounds good, i think i'll probably go with the 82 when it comes out, then upgrade to a dvi 720p scaled dvd player in a year or so. Can't afford the tv and the samsung player right now, and there will probably be more out, and possibly more firewire dvdaudio/sacd players as well to hook to my receiver. Progress is nice
post #32 of 4065
Whats going on with fox digital 9 ? (10-1) i am pulling in a strong signal but no picture. Its been like this for awhile now, i have rescanned always finding it and the guide, but no picture. Anyone else getting this?
post #33 of 4065
yep, same thing... sometimes the picture will flicker on for just a split second... but as a rule, it shows up as a strong signal that doesn't translate into picture or sound... (glad it's not just me ;-)
also, am curious: you guys refer to it as 9 or as 10-1... on my end, it shows up as 9.2... what does this mean?
thanks...
post #34 of 4065
Technically it is channel 9, but different stb's map it to different channels. My zenith 1080 maps it to 10-1.
post #35 of 4065
I found this CEA link that shows ABC and UPN Live dates as 11/01/2002.
http://www.antennaweb.org/aw/address.asp
Then you have to type in your address.
post #36 of 4065
argh, when is fox going to fix their digital feed...
Any info on if abc and upn will upconvert to 480p at least? Also wonder if upn will pass the enterprise hd feed. Hope abc goes hidef (doubt it) by the superbowl.
post #37 of 4065
That is if the Superbowl is in HD.
post #38 of 4065
True, but i believe it will be. We shall see.
post #39 of 4065
I got an E-mail from Joe Addalia [FOX] and here is where we are at.
_________________________________________________________
Hi Bobby,
We are waiting for an aspect ratio converter card. Since the FOX widescreen feed is SD its anamorphic and instead of switching our format converter in and out of anamorphic mode, we opted to do it right and use one aspect ratio. However if I knew it would take this long to do it right, I would have done something in the interim.
We spoke to the manufacturer, Miranda Technologies, this afternoon and they said any day now. I'm really sorry about the delay, it has just been out of our hands. The good news is all of the switching and automation is in place and ready.
We will install the card as soon as it comes in and start the widescreen FOX Network as soon as everything is tested.
Thanks for your patience,
Joe
post #40 of 4065
I wish that one of our local channels would add HDNet to their feed when the network is not braodcasting HD. They can get it for free from Mark Cuban. If NBC added it, they would be broadcasting HDNet most of the time. They can add their own commercials. Maybe, we ought to request they do it.
post #41 of 4065
Jerry, according to some post, some stations are already doing this.
Rick, call Mr. Phillips at WSRE and tell him that HDnet is "free" for the asking.
WSRE has no HD during the day so why not give Mark Cuban a call and show it during the day.
post #42 of 4065
Bobby, I think WSRE is happy with their daytime multicasting. This is apparently part of the PBS long range plan - multicasting a combination of regular programming and either PBSYou, PBSKids, or state/local education programming. Never hurts to ask.
post #43 of 4065
OK, you can take this for what its worth.
I just got this e-mail from Joe Addalia [Fox] about W/S.
Bobby,
We are going to be testing the FOX Widescreen switching tonight. If all goes as planned we will have it in place for every Primetime. FOX has not released any information on Sports yet, but we'll be able to pass that along as well.
Joe
post #44 of 4065
Got this update from WEAR ABC. Not the best news, but at least they are progressing. No HD from ABC this Fall.
Jerry,
We have taken delivery of our Digital Transmitter and our engineering
staff is working at the new tower site on various aspects of getting
ready for installation of the transmitter and antenna. Our target date
is still November 1st for being on-air. At the present time, our
equipment will only up-convert our standard analog signal to digital
format...we do not have the necessary equipment to broadcast
high-definition. That could possibly change by January, but we don't
know at this point.
Thank you again for your interest in WEAR-TV programming, and have a
very nice
day.
Joe Smith
post #45 of 4065
Fox 480p 16:9 is up and running.
post #46 of 4065
It sure looks great... for the split-second views of it that I receive...
Does anyone have a clue as to why...
* I get fine reception on the other digital channels
* the Fox channel has the strongest signal (by a small margin)
* the Fox channel produces either zero picture-and-sound or only brief flickers of it.
I have moved the antenna around without effect.
Any ideas re: fine signal and no picture?
thanks...
post #47 of 4065
I'm getting the same thing and have been for some time. I really don't think this is a problem on our end, but is on their end.
post #48 of 4065
I agree that it's not on our end. So, either it's on their end or else it's some kind of weirdness between here and there.
They're probably not gonna fix the problem unless they know it's a problem, so we probably oughta honk at 'em. I was hoping that somebody here would have a clue as to what it is, so that we'd know what we're asking them to do.
later...
post #49 of 4065
I have found that WALA's FOX digital channel is sometimes on 09-02, instead of 09-01. Try it, when it comes on for a second then go away. Let me know if it works.
post #50 of 4065
Ok, fox digital for the zenith 1080 has always mapped to 10-1. Its still there but i receive no picture, however if i pull up my channel guide then a picture appears in 10-1 that is the fox digital feed. It is extremely pixelated like i'm getting a terrible signal. My signal is about 90% maxed out on the strength meter, and i've never had trouble before.
Now i also have channel 9-1 that is suddenly on my channel guide. No picture here no matter what i do. Also get a strong signal. I've rescanned and 9-1 went away, leaving the strange 10-1 feed.
post #51 of 4065
9.2 is where I'm looking... it's the only place I've gotten FOX (I got the set a couple months ago, so never looked before then)...
post #52 of 4065
I sent WALA FOX an email about their mapping of the channel. The fixed the problem and sent me a reply. Check your Fox, it should be mapping to 10-01 now.
post #53 of 4065
I just rescanned, and it's still on 9.2 (which is ok with me)...
also, all the sudden, I can now get picture, but the sound is choppy... audio is in and out every few seconds, garbled to point where the channel isn't watchable... any ideas?
post #54 of 4065
Just for reference i moved my antenna very little yesterday afternoon, apparently it had started pointing upward a bit. Anyway yesterday i suddenly got fox in picture wise, but the sound was choppy. Now checking fox the sound is fine. I'm sure this all has less to do with my antenna than what fox is doing, but just throwing it out there.
post #55 of 4065
How far is Daphne from the towers at the Styx exit. I am 30 miles from the towers and get a 90 and above on Fox. I even get a 65 on CBS, which is my lowest strength signal.
post #56 of 4065
Not very far at all. Couldn't tell you exactly, but i know its less than 30 miles. Signal strength is no problem for me.
95- fox
80- nbc
75- cbs
55- wsre
i was just having the same problems russ was having with fox, but now i'm good. The only channels i really have a lot of trouble pulling in are analog 44 and 55. I have 55 watchable now (that is until i get my new set, then i'm sure it will go to hell.) but 44 sucks.
post #57 of 4065
I get Fox on 9.1 with my HD100. I am [was] not having the trouble that ya'll were having. Don't know why. 95- 97 signal strength. Daniel you live 20 miles or so closer to the tower than me. Your are only about 5-7 miles max from it. CBS tower will be about 5 miles east north east up hy.31 from the FOX tower.
post #58 of 4065
cool, explains why i have no trouble with those channels. Do you know where the towers are that have the wb and upn on them are?
post #59 of 4065
Cinder ask.
Daniel I have no idea.
post #60 of 4065
no problem, i'll figure it out.
