Is anyone around here using one? I would be particularly interested to know if any Mediacom customers on the Eastern Shore have successfully set up this card.
It is expensive, around $400. But you insert a cable card, and it has four tuners. The idea is that you use Windows Media Center as your DVR, and the device will eventually pay for itself because you are not having to rent a dvr from the cable company.
Silicondust is also coming out with a six tuner ethernet device in July, but it will cost about $500 and you have to use two cable cards with it.
I now use a Hauppauge Colossus card which allows me to use my Directv HD DVR as a tuner in media center. I also have an HD Homerun ethernet tuner for OTA reception, and they work great in Media Center. I have made many recordings using them.
But the great disadvantage is that you can only tune one satellite channel at the time using the Colossus. So when others are watching, I wind up having to use the Directv HD DVR to record shows, and then I transfer the keepers to hard disk in real time, tying up the Directv device from being used by others while I make the transfer.
I would consider going with the Ceton or the HD Homerun product to be released, if and only if the PQ produced by Mediacom with a cable card is equal to Directv. The last time I tried Mediacom with their Motorola DVR was circa 2007, and the results were, shall we say, far less than satisfactory. The low band cable channels were noisy and full of hash. Not pleasant to watch on a modern large screen flat panel TV. But the technician told me a cable card solution would produce a better result. I did not try it at the time.
But I would love to hear Eastern Shore Mediacom customers who are watching cable through a large screen plasma, lcd, led or the like, and hear a report on picture quality.
Thanks in advance.
