Two questions, the first is about the inputs. Is it possible to disable the inputs that I am not using so that I do not have to cycle through a bunch that I do not use?
Second, are the Smart Apps available for this receiver different from the apps available on Samsung's Smart TVs? There is one that I am looking for that is available for the Smart TV but I cannot seem to find on the receiver.
Well to my knowledge I do not believe there is a way to disable the inputs that are not being used. If there were a way, I would only have the dvd/blue ray (the home screen) and the Bluetooth as options. Reguarding your second question, I have no idea as I do not own a smart TV. Hope you find the answer to your second question.
Question 1 : No. Just use a programmable remote to automatically select the input/source.
Question 2: The receiver should list what apps it has just like the tv. Apps are updated often so if it's not listed initially it may be added later, or not. There's no real way of telling what's going to be added with updates. You'll just have to take a chance or find someone with F5500 and ask. What app are you looking for in particular?
I was looking for the RightNow Media app. I just looked at this link and found that it works only on TVs that are able to do the Yahoo Connected TV Store. Per haps it will work in an update...
Not every device is licensed to support everything, even within the same mfr. It's doubtful that your receiver will support the app, but again, that's up to the mfr.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
