I recently bought a vizio 701d-a3r tv and I noticed that when I turn the tv on, the brightness setting appears to default to 50, even though it shows the correct value in the settings, 36. If I change the brightness value by one, then the tv displays the correct brightness level that is shown. The same issue happens if I switch between picture setting profiles.I have this issue on all the hdmi ports, however it does not occur with in apps like Netflix and YouTube.
I have tried resetting the tv, but it did not help.
I purchased the M701d-A3R in July of 2014 and the screen has developed a darkening area in the upper right about 24" in and 3" down. I contacted Vizio and they gave me some things to try, problem is, the tv is no longer under any warranty so if their suggested troubleshooting doesn't work, I'm SOL. So I will start shopping for a new tv that isn't a Vizio. From what I have found searching the web, folks have had problems with their 70" tv's regardless of the model. Shame you spend that kind of money for what you think would be a well made product and get a worthless warranty and from an American company. I work for a place and we sell electronics that cost as little as $300 that carry a manufacturer 3 year standard warranty. Enjoy the money Vizio, you get anymore of mine and of course I'll never recommend you to anyone.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
