Hi - I've joined today and hope that I'm posting to the right area. I could sure use some help
I want to burn blu-ray discs from my dvr. I've just bought a Hauppauge 1512, a Pioneer BDR-2209, and a box of Verbatim BD-R discs. I gave it a try by copying a movie (via component) using Hauppauge Capture. That works fine, and creates a .ts file that plays back OK within Hauppauge Capture.
My problem is getting a usable blu-ray disc. My first try used the software supplied with the 1512, CyberLink's Power Director 10. It converted the file to .m2ts, which took around 5 hours (!) and then burned a BD disc. It played on my Oppo 93, but omitted portions of the film periodically, about 5 seconds missing each time. The time to do this, along with the defective recording, led me to try tsMuxerGUI followed by ImgBurn to create the disc.
I've tried the above procedure 3 times today; each time I've followed threads (various forums) to the letter for both procedure, and each time, the Oppo won't read the disc. Nothing - I press "play" and nothing happens. I've not done any editing, added menus, etc...just burned the BDMV and Certificate folders that tsMuxer created. Checking the discs on my computer, they contain 8 folders within BDMV, the main movie file within "Stream".
At the moment, I don't have a way to know whether tsMuxer or ImgBurn is the problem area. Can anyone suggest something else that I can try, or perhaps an alternate conversion/burning method? Any help would be much appreciated!
