Hi All,
I recently performs a firmware update on my TV then a reset to factory settings, after which I cannot receive free to air channels. I did notice that Australia is not in the area section in the setup, although I'm unsure it'd it was previously.
I used the same arial connection with another TV and that worked fine, so it seems a problem with the TV.
Any ideas?
Any ideas?
