Martysub Flatpacks ( I HAVE RETIRED FROM DOING THIS )
If you want a subwoofer that has amazing sound reproduction and don't have the tools to build it entirely yourself then this is the place for you. After four months I have built 35 flatpacks for various people. The only tools you would need to complete the sub with are clamps and a drill. I help you all through the process until you have a sub rocking. All flatpacks include :cut mdf to exact sizes
double baffle with cutout for driver and recess if needed
bracing strips
The Martysub is a ported subwoofer enclosure which was designed by Ltd02 and been expanded into several different sizes.
prices for flatpacks will be to the usa :
1) minimarty will be $289 us
2) Martycube will be $249 us
3) Microcube will be $219us
These are total prices shipped to you. Discounts for ordering two , pm for a quote.
Here is a list of some of the types with a graph below showing spl.
1) Full Marty (Green in graph) 2' by 2' by 4' ~ 17hz tuning in 11cuft box (1100 watts)
2) MiniMarty (Green in graph) 2' by 30" by 36" ~17hz tuning in 10cuft box (1100watts)
MiniMarty (Green in graph) 2' by 2' by 40" ~17hz tuning in 9cuft box (1100watts)
3) Martycube (Black in graph) 2' by 2',by 2' ~20hz tuning in 5 cuft box (1100 watts)
4) Just for fun the blue line in graph is 4cuft sealed sub (1100 watts)
5) Just for wows is the red line which is Martycube with Uxl18 driver (2200 watts)Drivers
For the below graph the driver is Dayton Audio RSS460HO-4 18" (except for red)
Other drivers that work are :
SI 18, uxl 18, as well as si 15 and ixl 18
MartycubesAccessories
$11 RCA Cable (which I had previously for the klipsch subs)
http://www.amazon.com/gp/product/B003FVVMS0/ref=oh_details_o08_s01_i01?ie=UTF8&psc=1
$5 RCA to XLR converter
http://www.amazon.com/gp/product/B000068O4D/ref=oh_details_o04_s00_i00?ie=UTF8&psc=1
$13 Speakon cable for each sub
http://www.amazon.com/gp/product/B000E1U4WY/ref=oh_details_o02_s00_i01?ie=UTF8&psc=1
$2.59 Speakon Panel Mount for connecting amp to subs:
http://www.amazon.com/gp/product/B00067JSFK/ref=oh_details_o01_s00_i03?ie=UTF8&psc=1
$8 Speaker Gasket Tape
http://www.amazon.com/gp/product/B0002ZPLPW/ref=oh_details_o01_s00_i02?ie=UTF8&psc=1
$2 Rubber Feet
http://www.amazon.com/gp/product/B002N5VYRI/ref=oh_details_o01_s00_i01?ie=UTF8&psc=1
$10 Acoustic Foam
http://www.amazon.com/gp/product/B0002ZPLP2/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1Tools
$30 Nail Gun
http://www.amazon.com/gp/product/B000EJW1ZY/ref=oh_details_o02_s00_i02?ie=UTF8&psc=1
$40 Jasper Jig (for cutting cirlces)
http://www.amazon.com/gp/product/B00009K77A/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
$9 Assorted Nails from 1" to 2"
http://www.amazon.com/gp/product/B00004YZQQ/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1For wiring up the subs go here and use the wiring wizard
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=&I=#resultsSpeaker Cutouts
For Si18,dayton 18ho, and uxl18, inside diameter needed is 16.75"
Outer diameter for flush fit for si18 is 18 7/16" and for uxl 18 its 18.5"Using Limiter in 4ohm bridged for inuke amp
93.8Vp is 1099.8 watts in 4ohm bridged mode
105.8 on 4ohm load is 1399.2 watts
For more info please PM me.
bracing strips
$2 Rubber Feet
$10 Acoustic Foam
$30 Nail Gun
