AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Memphis, TN - HDTV
Memphis, TN - HDTV - Page 198
post #5911 of 5998
Originally Posted by dex23462 View Post
Same issue, Fastoy. I'm in North Memphis and woke up Sunday 1/29 with a Tivo message stating all the 800's were moved into the 1000's. Thought maybe Tivo might be wrong, but checked the Comcast lineup online (which they finally updated after 2 years) and the new numbers are what is being advertised. Called Comcast, they pinged the cablecard, and then set me up with an appointment today 1/30. Of course the technician no-showed so I can't tell you what the solution is. Interestingly enough, if you manually go to the 800's the channels are still being broadcast there but of course there is no program information. I'm almost wondering if they promulgated the lineup change before actually rolling it out. It wouldn't be the first time Comcast did this. Haven't decided if I'm going to finally ditch cable altogether or not, but this is definitely annoying.
Ironically I think my non-geek wife figured it out. Her theory is that Comcast had scheduled the move for the weekend of 01/28/12 and communicated this to the program guide vendors (both their own and whoever TiVo uses). Then Comcast blew the implementation!
I suspect that some day Comcast will throw the switch and all will be done. In the meantime we'll have to do TiVo manual recordings.
My daughter in Olive Branch has the same situation as me. She has TiVo and Comcast STBs. Both are performing the same. My co-worker in Collierville has the 8xxs and 1xxxs in their Comcast STB program guide and signals on both 8xxs and 1xxxs.
Another fine Comcast mess.
post #5912 of 5998
I'm in the same boat here in Olive Branch. No simulcast of the 8XX's on the 1XXX's and my TiVo HD is recording a bunch of dead air. I have a coworker in Cordova who is getting the simulcast on both sets of channels so evidently the cutover worked for some of the Memphis market but not all. I spoke with a Comcast rep on Sunday night that said we should have gotten a notice of the lineup change via snail mail with a new lineup card. I didn't get any notice! Could it be that its working for the Memphis areas that have been through the digital conversion?
post #5913 of 5998
Wonder if we could get TiVo to give us a zip code specific program guide with the channels back on the 8xxs?
post #5914 of 5998
Tivo guide info is provided by zap2it.com. Comcast has probably handed the new line up over to them and it was updated by them too soon. I recently reported that channel 18 was coming up as WMAV in Oxford for several weeks on both Tivo and Media Center and 24 hours later it was corrected. I would expect we will see the new channels locations light up soon. It's about time for it too. I am tired of getting the fewest HD channels of all the providers.
post #5915 of 5998
What channels are the Memphis sub channels on comcast? I looked at the online guide and don't see them. Before the new digital switchover and if you had the cable directly connected to the TV you could go to 3-1, etc. How do you get them now?
post #5916 of 5998
I wondered about additional HD channels. I've been so preoccupied with the disconnect between the guide and the signals that I haven't looked at the channel lineup in the 1xxxs. Looks like there are lots more up there. They probably won't be in my package though!
post #5917 of 5998
This has been a long day for Comcast and TiVo. Overnight 01/31/12 my TiVo made the regular connection and ADDED back all the 7xx (I hadn't missed them) and 8xx channels. That seemed the right thing to do. But since they didn't DELETE the 1xxx channels my Season Passes didn't move back to the 8xxs. More in a second.
The Comcast rep. showed up on time this afternoon and didn't have a clue. He did text his supervisor and confirm that my "rate" was setup right. He wondered if Comcast had something set wrong on my account that was resulting in the 1xxxs not having a signal. All that was correct so there really wasn't anything he could do but tell me to wait until Comcast finished their rollout.
So then back to TiVo. Clearly they (in fact their program guide provider - Tribune) had realized that something odd was going on and added back to the program guide the channels they deleted over the weekend 01/28/12. However they left the new channels at 1xxx so the TiVo didn't refresh the Season Passes.
I called TiVo and they walked me through a variety of steps trying to get the TiVo to rebuild the Season Passes without success. I had even gone into "My Channels" and unchecked the 1xxxs.
The only suggestion that TiVo support could give me was to one-by-one cancel my Season Passes and rebuild them back on the 8xxxs. I did that for one and that was successful.
Not looking forward to this.
post #5918 of 5998
I got the TiVo update yesterday and it restored the guide info for my 7XX and 8XX channels as well. I also went into the channel config and unchecked all the 1XXX series channels. Although my season passes still showed they were going to use the 1XXX channels, they all appear to be recording ok on the 8XX series instead. So far so good!
post #5919 of 5998
I'll look tomorrow to see if some of my Season Passes that are still at 1xxxs are good recordings. I wonder if in your case you have signal on both 8xx and 1xxx. Could you check 803 AND 1003 to see? Maybe Comcast has lit up the 1xxxs in your area.
post #5920 of 5998
Bingo! I don't know whether this is intentional or by accident but I don't care.
My season pass was set for channel 1005 and showed as such in the "To Do" list. When it fired off tonight it actually began recording on 805. Now as it is recording it shows in the "To Do" list as 805. Future episodes still show in the "To Do" list as 1005.
I presume that the TiVo is looking through the channels and seeing that channel 805 is the same content as 1005 and just picking the first channel.
I'm keeping my fingers crossed.
post #5921 of 5998
Thats the same behavior I saw with my season passes. I checked again this morning and the 1XXXs have not been lit up in my neighborhood in Olive Branch.
post #5922 of 5998
I'm a Comcast customer in Olive Branch, MS. I currently have the HD Xfinity Preferred XF Triple Play package. I currently only receive HD channels in the 800-900 series range but I believe I should also be getting the HD channels between 750-800 (see screenshot below). Is there anyone else in Olive Branch or Southaven that is getting the HD channels between 750-800?
Attachment 237541
post #5923 of 5998
Attachment 237541
I live in Walls, just west of Horn Lake/Southaven. I'm not getting the channels either. They don't even show on my guide.
I hear we are getting new channels added but no word on when they will be available. Comcast is SO behind in the Memphis market.
post #5924 of 5998
I live in Southaven (south of Sam's) and don't have any signal on 750-800. They do show up on my TiVo's EPG.
I still don't have signal on any of the 1xxxs but after the trauma of last month I'm good with leaving well enough alone. However I'm sure that Comcast will complete their migration sooner or later.
post #5925 of 5998
Does anyone in the Memphis area have the DVR you can set remotely using DVR Manager? I believe it's Motorola. All I have seen are the Scientific Atlanta boxes which are not "eligible" for this service.
From Comcast/Xfinity website "DVR Manager is available in your area. However, we are unable to detect a compatible DVR in your household."
Of course, I can't get any useful info from Comcast.
post #5926 of 5998
Do DTA boxes have a program guide channel? How am I supposed to know what comes on what time on what channel?
Any cablecard PC tuner users in here? How is the experience?
post #5927 of 5998
How did you know when you just had the cable connected directly from the wall? I'm pretty sure if you want a guide then you'll need to get a regular STB.
post #5928 of 5998
There used to a scrolling guide on channel 3 I believe. It was between WREG and WMC.
post #5929 of 5998
Painless transition for the most part. I missed no recordings that I know of unlike with the Tivo where I missed several shows on various days where changes kept being made before signals appeared.
post #5930 of 5998
the two 3D channels are a hit. I just wish the xfinity 3d channel had more content and actually had guide listings more than 1 or 2 days a week.
post #5931 of 5998
Do you share the tuners? Any success wirelessly? My understanding is that it doesn't work well that way.
post #5932 of 5998
Anyone successfully using an IR blaster with the Pace DTA box? I have been trying for a couple weeks now.
post #5933 of 5998
all 4 tuners are on my Win7 64bit Media Center and are shared out to the extenders. I don't have any of them dedicated to another media center PC as I want recording and tuner sharing dynamic between all the extenders rather than loosing 1 for use only on a PC. I often have 4 shows recording at the same time.
I have 2 QAM tuners (an HDHomerun) they are not currently installed however. They did help in the case where 4 show record as they gave me 2 more tuners where I could watch The local channels in HD or SD. The basic SD channels and a few HD channels. It just takes a long time to set up the QAM tuners as they have to be done manually for each channel that is available in the clear over QAM.
My Bathroom TV is running wireless. Works fine for SD channels. Works ok for HD most of the time but you get a hiccup from time to time. HD works better over my 2.4 N+ network. Over-all it was more stable on a 5ghz A network. Which I still have running in my home. The DMA 2100's only do A on 5ghz.
sorry It took me time to get back and reply.
post #5934 of 5998
I have both TIVO Premiere boxes and a Comcast RNG200a DVR. On all units I'm getting pixellating on 1005 and 1013. It only seems to occur between 7pm and 10 pm. I've had Comcast out several times fine-tuning taps and connectors. I've got a strong signal that I lessen with attenuators. I've tried everything but cannot get rid of the problem. Both 1005 and 1013 reside on the 561 mhrz frequency. I'm beginning to believe that Comcast has a transmitting problem on that frequency. The db level and the SNR on that frequency is lower than any other. Anyone having a similar problem? Do most folks receive those 2 channels error free? Help!
post #5935 of 5998
Regarding my post of 3/14/2012, I finally got Comcast to look into a head-in problem with these 2 stations on the 561 frequency. They found there was an over subscription of bandwidth on this frequency. They adjusted the bandwidth and the pixelation went away. I've had 2 consecutive weeks of problem-free viewing on these stations.
post #5936 of 5998
Well, Comcast finally threw the switch in Collierville. Clear QAM 2-20 disappeared. There are a handful of clear channels coming through, most with only color bars.
I had to dig out the DTA and install it. Lots of channels now, but most are boxed severely. 16:9 inside 4:3 on 16:9 is painful.
Trying to figure out whether to buy a tuner and cablecard, try and talk Comcast into discounting an HD box, or going with uVerse.
post #5937 of 5998
A) did you re-scan?
B) Of course the DTA picture will be terrible it's analog output.
post #5938 of 5998
where my uncle lives in st. joe Mo. the HD box and channels are free on his service.
i don't know why comcast wants more and more.$$$...
post #5939 of 5998
I live in Southaven, MS just south of Sam's. I have a TiVo Premiere. Today my 803 and 810 started getting "Searching for signal on this cable channel..." Of course the 1xxx channels are still dead. After trying to talk to a Comcast rep. in the Phillipines, I hung up on her and started an online chat. At first he said it must be an in-house wiring problem then he went and read the notes on my area. He came back and said that the head end was being worked on and that channels would come and go until they were done?
Is anyone else in the Southaven/Olive Branch area seeing this problem? Did you get any better information from Comcast?
post #5940 of 5998
I live in Walls, west of Southaven just off Goodman Rd. and I have been experiencing stuttering, macro blocking and channels just completely dropping out where I get the "This channel should be available shortly" message. I called Comcast and got their off-shore help and they just keep wanting to reset my box which doesn't do anything. I hope that once they get their work done this will go away.
