Daniel, thanks. That is awesome.
Gut, the only place I saw a Silver Sensor (the only Silver Sensor they had) was at Sears at Wolfchase. I bought it. But you may be in luck, if they still have it, because I took it back. My cheap-o rabbit year gets everything just as well...
At the time I posted my hd darkness problems, I didn't know that my E86 can get NTSC SD channels, like 3 for CBS, for example (The SIR-T151 can't do that). Therefore, I thought that different inputs were the prblem. Guess what? On the same input on my Mits (DTV input), if I change from 0003 (CBS) to 28-1 (CBS-DT) on my E86, the picture goes from good to dark (talking again about the brightness and not PQ). The input is always at 1080i (set in the prefs of the E86), no matter if I watch SD or HD through my E86. What is going on? Is it the HD feed? If so, shouldn't all of you see the same things I am describing? Or is it my TV set when it it fed a true (how would it know?) HD signal? CSI was beautiful in HD, but my brightness setting was about 90%...
Any ideas would be appreciated. I know I am rambling, and i may not be making sense. Sorry.
Gut, how do you like the Zenith STB? Where did you get it? Man, it is pricy! I looked for on in Memphis locally, no luck.
Radu
Radu
Seems to be great, nothing to compare it to though. Very easy to set up and get running. CSI looked great last night, wish my wife appreciated it as much as I do. LOL
