I installed an OTA antenna last fall when Voom was a good idea. We tried a variety of items starting inside, moving to the attic and eventually ended up with a large Channel Master antenna on the gable end extending about 8 feet above the roof line. On this pole I have the large CM 3620 and a CM 4228 with CM 7777 amp on only the 4228.
This did work all winter until about April, as the stuff got greener the channels faded into the ether. At one time all of the local channels worked. Today PBS does not work and NBC is marginal, UPN is worse than NBC. ABC, CBS and FOX are OK, WB is good enough.
I think I am close but not close enough to function well.
Does anyone know of a Vancouver or Portland based OTA installer who could install something taller or bigger? I have plenty of room but the appearance may be a WAF discussion item.
nater
this is actually an addiction, maybe treatment would be cheaper
