Thanks Jeff! The design was functional. I wanted them near the ceiling due to a wall not shown which has a large opening in it instead of a door. So, I did up the room in UGNX (a CAD program) and built a model. I worked out an equation using the area of a trapeziod to allow me to vary the angle of the face while keeping the area of the trapezoid constant using the depth of the cabinets as a variable. I made a ray off the tweeter and modified the angle until it was aimed a little above the head of the sweet spot. This arrived at a 35 degree angle and gave me the final depth dimensions.
As far as the hanging method, I have seen picture frame hangers that work similarly. You have a piece of metal with an angle face that you hang on the wall forming a kind of pocket, and a triangle of metal that you affix to the picture. Then you just drop the pictures angled surface into the wall mounts angled surface and bingo, it's not going anywhere.
Using this method the speakers are very securely mounted. Each one has 3 screws in it, either through to a stud or using something like a drywall toggle, which is claimed to support 90 lbs each. The speakers only weigh 15 lbs.
Last night the only 7.1 capable DVD I could find was Gladiator with DTS ES. It sounded great and listening to other dvds, the 5.1 sounded great too. I was a little worried about the high mounting position (10 foot ceilings), but so far I am really happy.
Kevin
Kevin
. I wanted mine to disappear when the lights were dimmed, so I was forced to use flat-black to minimize reflections. You have a bit more brightness from your projector, so you can get away with a bit more light in the room than I and use a real wood finish.
I still need to cover the top with a dark fabric. Might not get to the equalization...
