bar projectors
post #1 of 2
I installed a LCD projector in a bar and it lasted less than 2 years. Just replaced the lamp a month before it died ($500). The Popcorn machine and smoke filled the internal parts and caused a meltdown. The unit was maintained every month by filter cleaning and washing.
No smokeaters in the bar and poor ventilation. I am sure this is common to most bars. $3700 down the drain. Going to replace it with 3 or 4 tube sets. Anyone want to buy a nice yellow screen?
post #2 of 2
I'm sure that you can take it and get the LCD panels cleaned and it should project just like new....I wouldn' t trash it until you price the cleaning....Steve.
This thread is locked
