AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Philadelphia, PA - Comcast
post #1 of 10685
The long awaited 2000 foot tower is now up and open for business. The first station to officially or unofficially go on line is UPN channel 57 (DT 32-1). All content was up-converted and looked pretty bad but they were the first new station on, none the less. We should not see any improvement to the station's content until the national feed sends Enterprise in HD next season.
Next up should be The WB network, channel 17 (DT 54-1). I placed a call to them last night to let them know that UPN beat them to the punch. They said they should be on by the weekend. That will be just in time to catch Tuesday's repeat of Smallville this Sunday (don't forget to set your clocks back an hour Saturday night.).
As for the other channels, who cares. Just kidding
I will update you on PAX Channel 61 (DT 31-1), Telemundo (I hope I spelled it correctly), PBS (WYBE-DT 34-1), and an Independent Station (WGTW-DT 27-1 ) as soon as I get the scoop.
May HD be with you always
DarthJedi
post #2 of 10685
Will FOX and NBC be on this new tower ?
post #3 of 10685
I am not sure about FOX but NBC will be moving to the new tower. Their transmitter is already there but they have not given a time for the roll over.
DarthJedi.
post #4 of 10685
Thank you for the info Darth. Would you know the transmitter power for UPN and WB?
-Ben
post #5 of 10685
Hopefully Darthjedi has more info on the transmitting power, but I can tell you that the UPN signal was fairly strong in Wilmington. On my HiPix I got a signal strength of 76 last night.
post #6 of 10685
-Ben
I don't know but I will find out for you. I can also tell you that I have the SONY HD200 and UPN is now the strongest signal I get. Before UPN it was CBS and ABC that were the strongest.
post #7 of 10685
That is surprising given that 57 is at such low power. Must be the height. It is my understanding that they have shut down the antenna right now. Let us know if you are getting it now. I no longer am!
post #8 of 10685
I am not getting it either.
post #9 of 10685
According to the FCC construction permit UPN WPSG-DT will be allowed up to 250kW erp from a height of 1312'. WB WPHL-DT: 500kW @1161'
PAX WPPX-DT: 800kW @1227'
IND WGTW-DT: 225kW @1099'
post #10 of 10685
They had people climbing the tower....That is why they went down
post #11 of 10685
Yeah, I printed out this thread, and was all excited to see the new channel when I got home.
Alas, it was not on.
Soon.....
post #12 of 10685
I'm glad it isn't just me not getting the signal. I got ABC, CBS, NBC, FOX and PBS. If the signal there I assume that I don't have to rotate the antena. last night I rotate the antenna like crazy, but still can't get UPN. I'll try again this weekend for WB. I forgot who posted, but he mentioned that WB will unofficially on air this weekend. We'll see.
Off topic - If UPN broadcast 76ers in HD, that would be great. Anyone know about this status? I heard that Comcast will install HD cameras in First Union Center. I hope that's not a rumor. I did not have comcast cable, so if UPN send the HD signal for the First Union Center, that would be awesome
post #13 of 10685
WPSG-DT is currently running about 8kw. Signal will go on and off, due to a variety of projects related to tower and transmitter... They will be ready for 24/7 on 11/1
post #14 of 10685
8kw? d to pick that up. When I scanned early yesterday morning, I was able to pick it up. Was that only 8kw? If so, that added height really helps. Hope they will be on at their maximum rated power of 250kw on 11/1. BTW. Comcast HD is strictly a cable product. I seriously doubt that it will be on OTA for a few years, at least with the use of Comcast euipment.
post #15 of 10685
Yes, from what I understand, FOX will also be on this tower.
post #16 of 10685
Fox will not be on this tower. They will be on another tower but much higher up and they will be at 1 megawatt. They should be up and running by the spring.
post #17 of 10685
OK, Now I'm REALLY confused! There are TWO towers going up in the Philly area? Can you claify what you mean by another tower? The info I got, and of course it could be totally wrong, said that WTXF (FOX)will be going on the same tower as WCAU (NBC) and WPSG (UPN), as well as WPHL (WB). JWhip - I hope you wrong, cause I can't get WTXF very well where I live.
post #18 of 10685
Fox will be moving their position to another tower where channel 35 (analog) is presently. They will be at nearly 1000 feet whereas they are at about 500 feet at another location in Andorra. Once they install their new antenna in the fall and go to their new power level (once the FCC approves it, you will have no trouble getting them.
post #19 of 10685
why can't we get any information on the status of WCAU? I can receive and maintain signals from every station except WCAU
post #20 of 10685
This is all good news! I picked up UPN by accident last week--what a nice surprise.
The only station I can't get hipix to pick up now is PBS--weird.
post #21 of 10685
i seem to have lost the upn signal (32.1) here in the philadelphia area. has it gone off the air?
post #22 of 10685
Yes. They tirned it off so that channel 17 could complete work on their antenna.
post #23 of 10685
I went looking for these stations all weekend, and didn't find either. However, I'm in the fringe and only using an indoor antenna at the moment. I'm probably going to try an attic antenna soon.
post #24 of 10685
I was told that a fm antenna was being placed on the tower today so no 32-1 was on. If it rains tomorrow, there will be no work on the tower. They will turn it on tomorrow if that is the case.
post #25 of 10685
Don't forget to check channel 54 tonight. WB said they will turn their signal on at 9pm tonight.
post #26 of 10685
Cool! Just in time for Smallville.
post #27 of 10685
8.8kw into antenna effective output from antenna 107kw - but all that matters not, since they are running to dummy load until the other folks clear off tower.
They might be back up in time for Enterprise - just get those people off the tower !!!
post #28 of 10685
Let us know if WB 17 is up and running and whether they will be staying on or just still testing!
post #29 of 10685
no WB yet
post #30 of 10685
Everyone Please join me in calling the WB and let them know that you are not getting a signal. They are saying it is on and I am not getting it I live one mile form the tower with a clean shot. The number is 215 878-1700 press 3 for news, ask them to transfer you to engineering
