Originally Posted by arneycl
Hi everyone. I live in Odon (Daviess County) and I have an antenna approximately 25ft in the air (not sure what kind but I had it installed about 5 years ago). There are some large trees around my house. I have an amplifier booster (not sure what kind). I am only able to pick up WVUT, WTWO, WAWV, WTHI. I would really like to pick up the Evansville stations (WTVW, WEHT, WFIE, WEVV). I provided the data below for those that know what all of this info means. Does anyone have any suggestions on how I could pull in the Evansville stations? I truly appreciate your advice/suggestions. Thanks!!!
Callsign Chan Network Dist (mi) Path NM (dB)
WTWO-DT 36 (2.1) NBC 34.6 1Edge 22.4
WAWV-TV -- 39 (38.1) 34.6 1Edge 20.9
WTHI-DT 10 (10.1) CBS 34.4 1Edge 19.4
WTVW-DT 28 (7.1) Fox 60.0 2Edge 6.1
WEHT 7 (25.1) ABC 74.4 2Edge -2.6
WFIE-DT 46 (14.1) NBC 71.9 2Edge -3.6
WEVV-DT 45 (44.1) CBS 72.4 2Edge -6.0
The ability to receive distant reception like that on a consistent basis is going to come down to several factors. Location is very key. Being in the sweet spot for the strongest signal is very important. When you are trying to receive stations beyond line of sight, almost anything can block the signal. It can be done, but it is going to take some antenna height, a high gain antenna(s) and fine precision wiring to get that signal delivered to the DTV receiver/tuner.
I know a viewer on the southeast side of Kokomo who can watch Fort Wayne DTV @ 66 miles and South Bend DTV @ 80-81 miles MOST of the time and these stations are all listed by TV Fool as 2 edge. But the terrain between Kokomo and those cities is mostly very flat. Even with WIPB, Muncie @ 45 miles, with his 48 ft. tower WIPB's signal is still within line of sight, whereas with your antenna height of 25 ft., even the Terre Haute stations @ 34 miles are not within line of sight, but rather 1 edge (below the horizon). The terrain in your area is going to make distant reception more difficult, unless you happen to be located on a nice hilltop (perfect!!).
I don't know what type of antenna you are currently using but the viewer in Kokomo is using a discontinued Channel Master 4251 (7 ft. parabolic UHF antenna) which might have been one of the highest gain UHF antennas ever made for residential use. Here's a great website with the history of the CM 4251. http://www.rocketroberts.com/cm4251/cm4251.htm BTW, this antenna in Kokomo was originally installed in 1975 and has been in use ever since.
Also, a very good (high gain/low noise) preamp is a must for your setup, too. One of the best, and widely used preamps when at some distance from local TV and FM transmitters, is the Channel Master 7777. In your location, you are going to need to boost those weak signals as much as possible. The viewer in Kokomo is also using this preamp.
That's my 2 cents in your search for info. I've messed around with a number of antennas, preamps, etc. in this area around Indy, but I'm not that familiar with the terrain issues and such around your area. Just because something works fine in this area, doesn't mean it will work in your area, or any other location. You may just need to do some testing (trial and error) to see what works or doesn't. I'd check with some neighbors or maybe a local/area antenna supply store (??).
Good luck. Let us know what you try and/or decide to do.
