AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Indianapolis / Terre Haute / Lafayette, IN - HDTV
Indianapolis / Terre Haute / Lafayette, IN - HDTV - Page 223
post #6661 of 6787
Originally Posted by nathill View Post
So it looks like one OTA station is not all that anxious to sell their spectrum....
6 p.m. today.....Well, I guess that wasn't set in stone.
Perhaps they're in the "try this" phase of the operation, and we'll soon see some progress.
Edit:
4 hrs past due....Not looking good for morning TV.
Anyone know if they finished the new antenna install?
Just tried TSReaderLite....got signal....hurray!
post #6662 of 6787
North side of Bloomington:
40 --> strong before on 16
40 --> strong now on 20
I think they're still working on it, because the two channels are showing the same thing. They both look very good.
post #6663 of 6787
Ya..... Dropped out again just before 11am.
Back again sometime before 1pm. .....Fingers crossed...
post #6664 of 6787
Hi all,
I've been lurking a while and finally decided to post. I'm half looking for advice and half providing some feedback on some things that are working for me right now. I currently live south of Bloomington, near Harrodsburg. I think my elevation is about 260m, but I'm not certain on that front. Because I live far out, I decided to cut the cord and try OTA. I built a DB8 antenna using instructions I found on instructables.com, but had mediocre results (probably because I didn't/don't know what I'm doing and it's housed in the attic). I then moved on to a great antenna, for the cost, that I found on monoprice.
That little sucker, pointed to the SSE, has been great! I'm able to get most Indy stations and just about all the Louisville stations I need. It does come with a low noise amplifier and I finally hooked it up last night as close as I could to the little antenna in the attic, instead of hooking it up in the living room. That did seem to help, as we now get WHAS out of Louisville in the bedroom. I'd guess that the antenna is about 35-40 feet off the ground in the attic and there's no window pointing to the south in the attic. So, if anyone is looking for a cheap, small antenna, that model may just be what you need (though, maybe my house is in such a spot that I'm lucky). And I believe their return policy and customer service is outstanding.
Having said all that, I still have some issues from time to time, but again, I just moved that little cheap low noise amplifier that came with it up to the attic and that may help considerably. Anything I should consider or change? A Channel Master preamp or Antennacraft HBU 55? Maybe get off my butt and strap those 2 antennas I made from instructables.com together properly and pair them with a Channel Master preamp (if I even made them right )? Any omnidirectional antenna that would help with receiving signals from Terre Haute, Indy and Louisville? See below for my TV signal analysis from TV Fool.
TV Fool
post #6665 of 6787
Anyone else experiencing issues about WXIN-DT's OTA signal dropping out in Marion?
Until Saturday, WXIN's signal was really good in the daytime and now today, have not been able to watch at all with poor reception in Marion. I watched bits and pieces of American Idol last night and very concerned that I might not be able to watch the American Idol results tonight.
post #6666 of 6787
I am within LOS of the WXIN tower and the signal is always in and out for me. The signal seems to greatly flex from aroung 70% to 100%.
post #6667 of 6787
WXIN signal is jumping all over this afternoon. It is unwatchable and I can see the tower out the window.
post #6668 of 6787
Big, if you can see the tower, you might actually have too MUCH signal coming into your tuner. People do not understand that (especially) with digital signals, too high of signal levels can actually cause just as many problems as too little. And sometime adding an amp only causes MORE problems for OTA signals, than what (they think) it solves. And, if you are getting (strong) multi-path signals, that only makes the problem(s) even WORSE then.
post #6669 of 6787
If you can see the tower, I'll bet you can get it with a paper clip stuck in the input jack on the TV. I can get WFIU here in Bloomington that way.
I would guess you're just getting way too much signal.
WXIN is rock solid here in Bloomington.
post #6670 of 6787
Mods: apologizies if this needs to be moved or deleted.
Everyone: feel free to flag if I missed something.
Anyway, I have no need for my set top box anymore. It's a really high quality unit (or, at least, it WAS 5 years ago...). However, I can't see any completed listings for it on eBay, and have absolutely no idea the best place to sell it. Anyone aware of a decent place in Indy I might get some value out of it? Or just put it up on eBay and hope someone bites?
post #6671 of 6787
I'm going to be moving to West Lafayette next month, and I was hoping to hear if anyone there has had any success getting the Indy channels. If so, what equipment are you using?
I'm also wondering if anyone knows of any installers in the area so I don't fall of the roof and kill myself.
-Bill
post #6672 of 6787
-Bill
I moved to the LaFayette area about 1.5 years ago (I'm on the south side). Originally, I was going to put up a tower. But, the time of year I moved, it was cold weather. So, I thought, "What the heck? I'll just put it up in my attic for now." My equipment--CM 4228 (original style) and a powered rf splitter (to feed four rooms). Well-to be blunt, I still have the antenna in the attic-haven't bothered with putting up a tower. Do I have problems with reception? Sort of. The main channels I have a problem with are 20 (WFYI) and 8 (WISH). They are marginal-especially during the afternoon hours (sun-fade? who knows). No problems in the morning or evening. For 8, it's not a big deal. 18 (WLFI) carries the same programming (except for local news). I'm positive that if I put my antenna outside (instead of the attic), there would be no problems at all. But, right now, for my viewing habits, my setup suits me. One benefit to having the antenna in the attic is that it won't be struck by lightning. Nor will the coax (and connector) weather degrade. The drawbacks-slightly lower rf reception level and no way to put a rotator on an antenna in an attic (confined area). If you still want to have a tower put up (which is the best way (signal strength-wise) to do it), go to LaFayette Electronics on Earl Avenue. They have business cards for people that will put up a tower for you. Short answer to your question-if you aren't in a valley (or blocked by buildings), you should have no problem getting the stations from Indianapolis.
post #6673 of 6787
Awesome, thanks a bunch! This is a big help.
-Bill
post #6674 of 6787
Here's a suggestion on doing a little research on how you MIGHT receive DTV stations, especially beyond 30-40 miles. When it comes to OTA reception, nothing is a given. We all know how spotty cell phone reception can be. Terrain and elevation factors between the station's transmitting tower and your receiving antenna can play a big part in how good or bad your signal strength is.
I live just south of Carmel in Hamilton Co. and one mile north of the Hamilton/Marion Co. line. I've always had a tough time receiving stations to the northwest, like WLFI, Lafayette and Chicago stations when tropo conditions are enhanced in the area. I have known that the terrain/elevation rises quite a bit in that general direction but didn't realize how much until a few years ago. The elevation above sea level (ASL) at my house is around 810 ft. The elevation within 7-10 miles to the northwest is 940-950 ft. ASL. That's a rise of at least 130 feet! In this same direction, I live 40 miles from the WLFI tower near Rossville and I'm 155 miles from the TV towers in downtown Chicago.
My VHF antenna is up 34 ft. on a crank-up tower. My reception of WLFI varies a lot. Anything from no decode (signal level just below the threshold of decoding) to a fairly strong and steady signal. As a test last week, I installed a temporary VHF antenna above the UHF antenna at 45 ft. above ground level. Wow, what a difference in signal strength. The extra 11 ft. in antenna height delivers a much stronger/steadier signal. The extra height was needed to attempt to get above the ground level and come closer to line-of-site reception. Now I'm waiting for some good tropo conditions to the northwest to see if Chicago DTV signals are any easier to receive.
Here's the site I used to find the elevation figures in my local area.
http://www.topozone.com/ A subscription is not necessary for the smaller maps and you don't have to download any huge files on your pc.
Steve
post #6675 of 6787
Great find !
post #6676 of 6787
My wife and I decided to finally take the plunge and cut the cord from Comcast in West Lafayette. We have subscriptions to Hulu Plus and Netflix, and are looking into OTA TV. What sort of rig would we need to ensure getting WTHR and other Indy channels. I know that WLFI comes in with just typical bunny ear antennas, but do we need something mounted to the roof for WTHR and other Indy channels? It would be great to hear from someone in the area on their experience with their setup.
post #6677 of 6787
See my above response (#6672). If you have further questions, please let me know.
post #6678 of 6787
Perfect! Do you have any issues specifically in getting WTHR? We are huge thursday night NBC fans, and hope that it comes in well enough.
post #6679 of 6787
No problem at all. As mentioned, since my antenna is in the attic, my main problem station is 8 (WISH). But, 18 (WLFI) carries the same (CBS) programming (except for local news).
post #6680 of 6787
I'm on the other side of Indy from you folks, (Anderson) and I also have issues with RF9 Ch 8 CBS. You might try their UHF low power channel 17.1 .2. .3. It always seems to come through for me when the VHF channel is dropping out.
post #6681 of 6787
WISH-TV's translator on RF 17 most likely won't make it up to the Lafayette/West Lafayette area. The translator is directional to the southwest. They must protect WYIN Gary, who also broadcasts their station on RF 17. West Lafayette is probably about 80 miles SE of Lake Dalecarlia (an unincorporated part of Lake County between Cedar Lake & Lowell), where WYIN's tower is located. So kevinoshea might have a better chance of getting WYIN than WISH-TV's translator.
post #6682 of 6787
Hey all. Been busy, haven't been around much. Bought a house and moved recently. Previously had been in a third floor apartment and now in to a two-story house surrounded by trees. My OTA signal has overall stayed pretty decent, but even before the move WISH had been poor. Now, WISH is unwatchable using my cheap indoor flat RCA antenna. I'm located just south-west of the intersection of 56th and Reed, on the West side - south of Eagle Creek Park.
I've been reading good things about the Mohu Leaf, so decided to pick one up. Immediate results. Go from being unable to get a lock on WISH to immediately getting a lock with a strong signal. Impressive for what is basically a laminated sheet of paper. I do have an attic area above the garage where I could put a bigger antenna, and I still might eventually, but thought if I could get by with something simple like this I'd stick with it. I have the 'Leaf' pointed out an east-facing window on the second floor. This room has a vaulted ceiling, so its pretty high up -- although I could still move it up another 3 feet in the middle of the vault (though would no longer be pointing out the window).
Anyway, I'm mostly just rambling and wanted to say Hello again. Ciao!
post #6683 of 6787
If you're in or near Indianapolis, as it shows by your screenname, then you're most likely picking up WISH-TV's translator on RF 17, & not the main WISH-TV on RF 9. Do you get WTHR on the Mohu antenna? WTHR does not have a translator, & solely relies on their VHF signal on RF 13. So if you're not getting WTHR, then you're most likely not getting WISH-TV via RF 9. Indoor antennas don't work as well for VHF signals. Where I work at up in Merrillville (not in the Indianapolis area of course, but making a point here), I was using a regular outdoor antenna for picking up TV stations while working on weekends (antenna used indoors). I did not get a single VHF station, because the building didn't have many windows to allow VHF signals to travel through. That meant I didn't get WLS-TV on RF 7 or WBBM-TV on RF 12. I got most UHF signals, but didn't get the weaker UHF signals that were less than 250kw.
The fact is, unless you have a home with lots of big windows, chances of getting VHF stations steady are slim with any antenna indoors. My current home in Gary doesn't allow any stations thru, & must have an antenna outside.
post #6684 of 6787
It's always nice to have a backup plan for a rainy day. In this case, I'm glad I have an OTA setup this evening as my cable (BHN) went out at 7:59 p.m. Nothing like paying for a service that's not available.
I'm currently watching the preseason NFL game between Cincinnati and Atlanta on Fox, WXIN. After watching the Olympics on NBC I keep waiting for parts of the football game to be cut or edited or censored. Here's hoping NBC presents the Colts game live without edits (all four quarters) Sunday night.
post #6685 of 6787
I'm in Lafayette and am wondering if the MOHU Leaf would give me any difference than the old fashioned twin dipole wire hanging on the wall in a T config?
I can only get the local WLFI and wondered if the MOHU would allow any of the Indy stations or the Champaign station to be seen.
post #6686 of 6787
Champaign reception from Lafayette demands a full-blown outdoor (or perhaps attic) antenna. No indoor antenna will cut it on anything outside of a terrific opening. (If it did, Indy reception would be daily for me, instead of once or twice a Tropo season.) However, with a good indoor antenna, you should at least get WTTK on RF 29, and maybe even some of the stations from the antenna farm in Bloomington.
post #6687 of 6787
Bloomington is 100 miles from Lafayette, has no antenna farms, and has only a local PBS affiliate (WFIU). I really doubt there is much of a chance of getting WFIU from Lafayette with any setup.
There is also a smaller antenna farm in Trafalgar, but I doubt reception from Lafayette is very likely.
Indianapolis has an antenna farm located about fifty miles from Lafayette, and I would think if you're on the south side of Lafayette, a good outdoor antenna would make reception likely.
Ask Goldrich for his advice. (post 6674 above is great).
post #6688 of 6787
I hadn't realized just how far Lafayette was from Bloomington. It's about as far away as I am from Indy. I think I may have underestimated the distance between Indy and Bloomington. I thought the antenna farm was on the south side of Indy, which is why I confused it with Bloomington. Is it on the south side of the city, or was I mistaken? Still, the Mohu Leaf should be able to get Indy, and Champaign is out of the question.
post #6689 of 6787
The Indy farm, which has a whole bunch of transmitting antennas, is on the north-west side of Indy which makes it about as far from Lafayette as it is from Bloomington.
I live on the North side of Bloomington, and with a 25 feet outdoor antenna I get all of the Indy tree farm stations rock-solid.
I don't think I'd have much luck getting them solidly from indoors, but have never really tested it.
post #6690 of 6787
The Indianapolis antenna farm is on the northwest side of Indy, closest to Lafayette. And there is an antenna farm south of Indy in Trafalgar (southwest Johnson Co.) which is for three stations licensed to Bloomington-Indianapolis: WTTV, WIPX and WCLJ. As Nat mentioned, WTIU, Bloomington (PBS) has its tower on the southeast side of Bloomington.
I live just south of the Carmel city limits and I'm located 37 miles from the three towers in Trafalgar. From the Indy antenna farm towers to the south side of Kokomo is around 37-39 miles. Lafayette reception is much more difficult to predict due to the terrain issues. If you live outside the city in a fairly high, flat area, I'd speculate that reception of the Indy stations is quite good. If you live in the city of Lafayette, down in the valley area of the Wabash River, reception of DTV from Indy is going to be much more difficult. The strongest and easiest reception is line-of-sight, when the receive antenna can virtually see the broadcast tower. Anything between the two points can greatly diminish the signal strength.
As for steady reception via an indoor antenna, it can be hit or miss. You never know until you try.
