Over in the HDTV Programming forum there is discussion about DirecTV carrying CBS HD, and especially the Superbowl. There are a bunch of limitations and requirements that I don't understand. If anyone does understand it, post here wether or not DirecTV/Pegasus customers in Indy and outlying areas like Kokomo will get this.
http://www.avsforum.com/avs-vb/showt...hreadid=347953
Edit - I think I understand it now. Since Indiana's CBS stations are affiliates and not owned & operated by CBS, we will not be able to get CBS HD via DirecTV. Unless you live in a remote corner of Indiana where you don't have access to any CBS OTA signal. Enter your zip here http://directvdnseligibility.decisio...pp/display.asp to see if you are eligible.
. And thanks all for the breakup insight. I climbed into that *^&#$^% attic again and tweaked the silver sensor a bit. I rarely see it, usually during superimposed graphics (ad's). Nothing I can't live with...
