Originally posted by KBandy
fgr41, where are you? I am just south of Bridgeport and Morris. You've got the same line up we do. As far as why WRTV doesn't say "6" instead of 25, that is done via channel mapping software at the broadcaster. Probably either personal preference or lack of capability of the equipment is why they don't.
I'm with you on the program guides. As far as I know, the only local station that sends the guide info is WISH.
I'm in Avon, and have to say that the sig strength I get is impressive. I have an attic antenna and am using a amp that was left from Time Warner cable. I was worried because the cable from the antenna is not very thick gage and has a union 1/2 way on a 75 foot run that then gets put into a diplexer to combine the DTV and OTA signals, then split in back of the TV. The weakest signal I get is 85, most channels are in the high 90's.
It's great to see so many stations doing DT here. I think there is only one more station I'm waiting on and every local channel worth watching will be DT. Now if only WRTV would do channel mapping I would have nothing to whine about.
