Since starting this thread four years ago, things have changed a bit. I unfortunately don't live in the 'Burgh anymore (thanks U.S. Airways), but someone who does has thoughtfully provided a new update.
There are some new developments here in the 'Burgh, and I thought it might be nice to have one spot to gather everything together.
The Good:
WYTV, the ABC affiliate in Youngstown, is on the air. For everyone on the North side of town who can't get WTAE (and that includes just about everyone), this is awesome news. They're not yet on 24/7, but they've been lighting up the transmitter when ABC has HDTV programming. I've been able to pull it in using my less that perfect attic antenna setup, so a good percentage of us should now get ABC in HDTV and DD 5.1. Can you say Super Bowl?
Also, WQED is playing with their setup. As noted in another thread, they've been multicasting on 13.3, 13.4, 13.5. and 13.6 during the day. The plan is to use the full datastream for PBS HD programming. The demo loop appears to be history already.
KDKA and WPXI continue to put out quality, high-power signals. KDKA should be DD 5.1 sometime next year.
The Bad:
WPGH-DT is up and running of course, but at 480i. No HDTV here anytime soon.
The Ugly:
WTAE is at flea power, and will stay that way for years. Now that I can get WYTV, I really don't care.
WCWB (WB22) is also at flea power. Another Sinclair-owned station pushing the digital transition.
WNPA (UPN19) is currently awaiting FCC approval on a proposal to change the original DTV channel allocation and move the transmitter closer to the city. The application has been at the FCC for a year and a half, but they haven't yet heard anything. Once a construction permit is granted, it will take several months worth of work to get up and running, but Viacom has budgeted the money to make it happen.
Originally Posted by benji15301
As far as WYTV, I believe they're up and running at full power 24 hrs. although I cannot receive their signal here in Washington County. All Youngstown stations are up and running but I can only receive WKBN-DT's signal. WFMJ's signal is blocked here by a stupid idiotic low power signal on analog channel 20 by WBGN-TV. WKBN-DT is multicasting with a FOX feed on 27-2. Picture quatlity on 27-1 is good, but 27-2 is mediocre.
WQED-DT is only operating on channel 13-1 as a full time full service HD outlet. I denote no simulcasting here. WQED-DT has awesome PQ.
KDKA-DT and WPXI-DT are operating full time with full power with HD programming. WPXI-DT is multicasting with NBC's Weather Plus (worthless to me, I'd rather see a full time doppler radar) on 11-2. Both are utilizing Dolby 5.1 technology. Both got great picture quality although the audio on 2-1 (KDKA-DT) is too loud.
WPGH-DT is up and running 24/7 with a multicast. 53-1 is HD and 53-2 is SD. 53-1 has great PQ.
WTAE-DT is up and running 24/7 with full power. I have absolutely no problem receiving thier signal here in Washington County (South Strabane Twp.). Thier PQ on HD broadcasts is 720P and is great. Their PQ on all other (upconverted 420) broadcasts leaves a lot to be desired. Very smeary looking. I have been quite disappointed with thier non-HD quality for a long time, but it doesn't look like they're going to do anything to correct it.
WCWB-DT is also up and running full time. As with WPGH-DT, their PQ on HD broadcasts is great. WCWB-DT is multicasting a music channel (I believe "The Tube") on 22-2.
WNPA (analog channel 19) is STILL waiting for FCC approval to go digital. Their allocation on channel 49 is used by a low-power outlet in Indiana County and the owner of that station is single-handedly blocking their firing up digitally. They've also asked the FCC for permission to use channel 30 but thus far to no avail.
Hope this helps.
Hope this helps.
The Good:
The Bad:
The Ugly:
