I posted a message a few days ago stating how pleased I was with my new M2500 screen. Now after a week of using it I'm less thrilled. There are two image problems I've noticed:
Hotspotting: My projector is on the floor and my eyes are below the center axis when seated. Because of this, the hotspot is below center. This makes the upper portion of the image particularly dark. When I stand up such that my eyes are above the center axis the hotspot falls pretty much in the center of the screen and the light dropoff towards the edges is less objectionable. The best illustration of the dark upper portion of the image has been the World Series. The batter is in the center of the image and the pitcher is near the bottom. The hotspot from my seated position falls between the two. So what happens is that the already darker stands behind the batter are really dark. I compared the image to my direct view TV and while the fans are easy to distinguish on the direct view they are murky on my FPTV.
Color shifting: This one is a much bigger problem. There is a significant color shift from red to blue (left to right). It's very obvious with an all white image. It's generally not too noticable with moving color source material. But I find it objectionable with B&W source material. I watched Blair Witch over the weekend and the color shift was noticable and distracting during the B&W 16mm portions of the movie.
The hotspotting is a minor problem. For this and other reasons I'm probably going to end up mounting the projector on the ceiling. I was trying to avoid this because the low (under 7 feet) ceiling in my basement.
I guess I'm just going to have to live with the color shift. I'm surprised that I haven't seen this mentioned by others as a bigger problem. I consider it pretty severe. If I watched a lot of B&W material it would be unacceptable. As it is, I still think the tradeoff between these problems and the brighter image is worth it. But it's a close call and I definitely wouldn't give this screen material an unqualified recommendation. My recommendation to others with CRT projectors would be to only go this route if you really feel you need the higher gain screen and realize that the higher gain doesn't come for free.
My projector is a Sony 1270Q, floor "mounted" about 95 inches from the screen and I sit about 130-140 inches from the screen.
-Dylan
-Dylan
