AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › does the ae300 have a sideshot feature?
post #1 of 9
i was planning on putting it on a corner of the room.would i be able to set the pic in the middle or is that jus a sony thing?
post #2 of 9
Yes.
Suzukino
post #3 of 9
I think he means yes, its just a Sony thing.
post #4 of 9
The HS10 has digital keystone correction called SideShot 2 which lets you project an image from offset angles, dont forget though that while the picture be square to your screen the light wont be, and also most people hate keystone correction because usually it degrades picture quality although nobody has yet tried using this feature to see how useful it is on the HS10 (still waiting for a comprehensive review).
The AE300 only has vertical keystone correction so it has to be in line with your screen. The AE300 clone from Sanyo (PLV-Z1) has a lens shift feature which lets you actually move the projector lens up/down/left/right. This means that the image can be projected from the side and the picture/projected light will fit wherever you move the lens to.
post #5 of 9
Actually, the AE300 does have side keystone correction (digital). It's the AE200 that only has vertical keystone correction. This information comes from the Japan AE300 product brochure.
post #6 of 9
KOOL IF WHAT YOU SAY IS TRUE THE AE300 IS A SUPER BUY ..I CANT WAIT :D
post #7 of 9
Hi,
I can confirm that the AE-300 has side keystone correction (digital), and I will never use it!!!
But at the moment it is sent return for replacement of a dead pixel :D
post #8 of 9
does it take away from a good picture when you use this side feature?
post #9 of 9
I meant, "Yes. the AE300 has a 'sideshot' feature." But, in this case, as pointed out, it's more correctly called horizontal and vertical digital keystome correction.
Suzukino
This thread is locked
