Originally posted by superbat
Hi,Lakesidex:
Mine is a Sammy hlm507w,I have the same problem with you.How did make it working?Thanks,any one can help me?
Wow I just saw this. Sorry so late.
My problem was recurring until I figured it out.
I think there is a short somewhere.
When I push in a component cable the TV shorts out. Then a single green lamp light blinks.
With 1 set of component cables plugged in, either component 2 or 3, my HLN61 would not start. Again, just a single green lamp light blinking.
Try turning on the TV with no component cables.
If that dosn't work I would power up the tv, press in the red component cable then pull it out a couple of times.
I don't know if this is wise advise but since I had no real warranty I didn't have much to lose.
Good luck!
