I can't seem to find a North San Diego post, so I think this one may have the most people in the same bind I am - not too close to either SD or LA. I am opposite in that I am closer to SD, but otherwise the same. I am up on a hill, and there is no HOA or even nearby neighbors, so I can put up a "major" antenna without any fear of repercussions.
After doing some research on this board and other boards, as far as I can tell this may be good for what I need:
CM3671 (antenna)
CM9521 (rotor)
CM7777 (pre-amp)
Even for just SD channels I don't think multi-directional would work - I'm too far away. So I think a directional one that I can rotate would work best. Does anyone have a setup like this? Does it work well? Right now I have Cox, and I hate them with a passion, so I'm thinking of getting DirecTV, which is why I'm also looking for an antenna setup.
Along these lines, is there a recommended box for combining DirecTV and Antenna signals?
Thanks in advance.
CM3671 (antenna)
CM9521 (rotor)
CM7777 (pre-amp)
Thanks in advance.
