AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Los Angeles, CA - OTA
Los Angeles, CA - OTA - Page 284
post #8491 of 9089
Originally Posted by phildaant View Post
dx?
DX: receiving distant broadcasts
http://en.wikipedia.org/wiki/TV_and_FM_DX
While in Dover, DE I occasionally received DTV from DC and on rare occasion got it from NYC. And yes I did receive both WMAR and WCBS (both mapped to 2.1) and they both mapped to my channel list quite nicely.
post #8492 of 9089
Not 5 minutes after my last post, I checked my email and I see an email from Mr. Mayhugh filling me in on what was going on with KFLA, responding to my email of June 12. Thanks for the response Mr. Mayhugh. Welcome to the forum.
When I got home from work, I did a scan and lo and behold, there was KFLA and I caught the tail end of "Starsky and Hutch." I am also getting KIIO 10.5. Does anyone know what their programming consists of? I thought it was supposed to be Luken's PBJ Channel, but it appears to be some washed out foreign programming. I can't tell whether it is Spanish or some other language. Any thoughts?
post #8493 of 9089
Originally Posted by retiredengineer View Post
I can't receive KFLA on RF8 in eastern Anaheim and I think I know why, adjacent channel interference from RF7 and RF9. This occurs if the adjacent channel power is 10 dB or more stronger than the desired channel. At my location the received power of KFLA is 50 dB less than KABC or KCAL per TVFool. No receiver can handle that power difference.
How are some people receiving KFLA considering the ERP differences?
FYI: ATSC A/74 Receiver Guidelines as well as CECB Specs indicate that
a DTV signal "should" tolerate adjacent DTV channel interference
that is 33 dB HIGHER than the desired signal for normal signal levels
and 20 dB higher for a strong desired signal level.
post #8494 of 9089
Originally Posted by holl_ands View Post
FYI: ATSC A/74 Receiver Guidelines as well as CECB Specs indicate that a DTV signal "should" tolerate adjacent DTV channel interference that is 33 dB HIGHER than the desired signal for normal signal levels
Thanks for the information. Is there a 'tolerate number' when you have both an upper and lower adjacent DTV channels? e.g. strong RF7 and strong RF9 interfering with weak RF8.
post #8495 of 9089
Originally Posted by Drewdawg View Post
This is excellent news for those of us who are blocked from Mt. Wilson by too many hills.
Yea, I have Verizon, but I'm old school and like OTA options. After all, it's hard to DX with FiOS.
if you have any luck with mt wilson, im jealous but watch SD tv is better than nothing
post #8496 of 9089
From Van Nuys I'm now able to get KFLA for the first time. Coming in well, too. Also 10.5 KIIO, didn't used to get that. KOCE is still hit or miss. I have yet to check if the antenna is OK. We'll see.
post #8497 of 9089
I don't recall any, but would guess that the margin would decrease by 3 dB,
due to contribution from TWO interference sources. Bear in mind that these
are all ballpark numbers when it comes to REAL antennas and REAL multipath
fluctuations and REAL propagation variances....as always...YMMV....
post #8498 of 9089
I live in Placentia CA 92870 (by Anaheim) and am using the following HDTV antenna:
http://www.monoprice.com/products/pr...#specification
Which also includes a small line amplifier. It is a great antenna (read all the reviews). Mounted outside on a second story eve, pointed to Mount Wison. I get pretty much everything except can't get a good signal for Channel 7 KABC even tohugh I have a clear path.
I see alot of talk about channel 7 for my Orange County / Los Angeles Neighors experiencing difficulty with this signal as well.
Not sure what my options are for this particular channel, or if I fully understand the issue. I previosuly tried repointing my antenna a bit with no luck.
Any ideas on a solution.
post #8499 of 9089
Despite the claims, that antenna is not really designed for VHF, which is where KABC broadcasts. The 20+ dB claim is all due to the amplifier, which DOES NOT REALLY HELP dig out weak signals. Amplifiers only preserve the signal received by the antenna from getting lost in the cable to the TV.
To be sure what antenna is best for you, we would need a reception report from tvfool.com (share the report's URL, not just the pictures.) However, I would guess a small Hi-VHF/UHF antenna like the RCA ANT-751 would be just fine.
post #8500 of 9089
Originally Posted by Guitar1969 View Post
I live in Placentia CA 92870 (by Anaheim) and am using the following HDTV antenna:.....
.......... It is a great antenna (read all the reviews). Mounted outside on a second story eve, pointed to Mount Wison. I get pretty much everything except can't get a good signal for Channel 7 KABC even though I have a clear path.
Usually difficulty with reception of a strong LOS station is due to too much multipath. You need to find the 'sweet' spot where multipath interference is minimum. You can try raising or lowering or rotating your antenna to see if it makes a difference. Have someone look at the signal quality meter on your TV while you are moving the antenna.
Or try tilting up or down since you have a flexible mount.
post #8501 of 9089
There's another angle: overloading the amplifier from too many strong DTV signals or harmonics from a nearby FM station. Anybody in the LA metro with a clear shot at Mt. Wilson should NOT need an amplified antenna of any sort, especially if said antenna is mounted outside. Barring evidence of terrain blockage in this case, I dare say the monoprice antenna is working despite itself.
post #8502 of 9089
I assume one can look for this station on http://www.antennasearch.com/ ?
post #8503 of 9089
KOCE-DT is broadcasting on channels 50.1 (RF48) and 31.4 (RF23).
KOCE on RF48 works great in my area - no picture nor sound breakups.
btw, I can receive KFLA on RF8 in my area with no picture/sound distortions, even when my TV is just using an indoor rabbit ears antenna.
there's now spanish programming on KVEA 52.2 - channel is now called "Exitos"
post #8504 of 9089
Use FMFool to see if there are very strong FMs near you. Use TVFool for TV broadcast. Antennasearch looks useful for cell phone and other towers.
post #8505 of 9089
Unfortunately I don't have a solution, but I live near you (Fullerton 92833, right near the 5/91 interchange). This is the antenna I have on my apartment balcony (facing Mt Wilson with a clear line of sight). I get KABC just fine with no amp. In fact someone suggested I split my incoming signal to weaken it a bit due to what was said above (the signal overloading my Tivo's sensitive receiver chip, resulting in bad reception). Doing that, I got slightly better numbers on my Tivo's signal meter, but didn't notice any spectacular difference other than that (but I wasn't really having a big issue in the first place -- just a problem with KDOC, which wasn't related to reception anyway).
There is an occasional glitch on KABC, but frankly that seems to happen on all the channels I receive. Might be due to the Fullerton Airport which is located between me and Mt Wilson...
post #8506 of 9089
The CM 2016 is a decent antenna. It does have more UHF gain than VHF, which kinda goes to waste. The ANT751 is more balanced I -think-.
post #8507 of 9089
The good news is we still get KFLA. The bad news is there's no tivo programming info yet.
We watch zero live TV, so hopefully tivo(tribune) will realize the remapped stations soon.
post #8508 of 9089
Originally Posted by mayhugh View Post
KFLA - Channel 8, Los Angeles will change over to it's new higher power channel 8 transmitter and antenna Saturday afternoon (12/31). Viewers must do a new scan of their TVs to be able to continue to receive KFLA's programs.
Those wanting instructions to scan their TVs will find them at our website - kfla.tv.
We sincerely thank everyone for their support.
Roy Mayhugh
KFLA, Channel 8, Los Angeles
PS being a new "poster" to this forum I was not allowed to post the links to our website - sorry for the inconvenience.
Welcome to LA OTA! Glad to have you aboard, Roy. Thanks for sharing the information. Love retro tv, so I'm a KFLA fan.
post #8509 of 9089
Just a reminder folks;
As expected, Universal Sports formally on KNBC's sub-channel 4-4 is no longer available free OTA as of 1-1-12, and is now a pay television only channel.
post #8510 of 9089
So, what's replacing on 4-4? Nothing?
post #8511 of 9089
Nope, nothing it seems for now at least;
My OTA channel list now just skips from 4-2 (California Nonstop) over to 5-1 (KTLA's main sub-channel).
Have Universal Sports on DIRECTV ch. 625 though.
post #8512 of 9089
Ah thanks. I will tell my tuners to delete 4.4 then.
post #8513 of 9089
Directv has Universal Sports but it looks like nobody else does. Wonder if the drop in viewership is similar to KCET's drop when the later left PBS.
Anyway, it looks like KSCI joins KVMD 31.x, KXLA 44.x, and KJLA 57.x (if you count 23.4) in the 10 subchannels club. There are currently no Vietnamese channels on KSCI, so why not? I will guess one is coming.
post #8514 of 9089
Roy Mayhugh
Does the guide info come via KFLA automatically. TiVo is not recording for me because of lack of guide data. I wanted to confirm that data is being delivered by KFLA before I email Tivo to update their software. Thanks.
post #8515 of 9089
Same here. I can tune KFLA in on the AM21 runner hooked up to my DirecTV TiVo receiver (THR22), but cannot record due to the lack of guide info. I tried to set up a manual recording but it does not record. When I check the recording history, I get a message that says the channel was removed, but it is in my channel list. I emailed TiVo a couple of days ago and received a message someone would get back to me in 3-5 days. Anyone have any ideas what could be the problem?
post #8516 of 9089
It's a question for TiVo community, definitely not in this thread. As I understand you see in a guide the channel on your THR22 ? Then manual setting - start time and duration should do that. Regardless guide info; all info to tune is there - freq,TSID, PIDs, etc
post #8517 of 9089
If someone could tell me if KFLA is sending correct OTA guide info, then I would know its a tivo issue. Until that is confirmed, Im not absolutely positive who's at fault.
post #8518 of 9089
Yeah whatever, I started a thread in tivo community days ago. Obviously "Tivo/OTA-only" is a small percentage of users. The tivo community is great, but how many are in LA and OTA only?
This is about OTA and this is Los Angeles, heaven forbid if it relates to OTA directv or OTA fios or OTA tivo, along with it.
Definitely some boorish people here.
post #8519 of 9089
Well stated, Turbobuick86. This is a complicated issue. As you stated, you are trying to determine the source of the problem. On a stand-alone DVD recorder hooked up to my OTA antenna, I cannot get any programming info for KFLA either, so I have a feeling it might be on their end.
post #8520 of 9089
I mainly watch 2-13 but occasionally will surf to other channels I have programmed when I'm bored.
Is there a channel guide available somewhere that tells me descriptions of the programming? I don't want to re-run the auto-scan as its a real pain in the ass on my TV to hide channels once they have been added.
