AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Los Angeles, CA - OTA
Los Angeles, CA - OTA - Page 292
post #8731 of 9089
Originally Posted by WA5IYX View Post
One of the mid-1960s April CQ Magazine articles dealt with how to use invisible paint to hide your huge tower/antenna systems
Here tis!
post #8732 of 9089
Hello.
I get very few OTA channels on where I am moving to and most likely be
getting cable TV, but it won't have all channels that can be fed with
OTA (same for satellite services). Is it possible to merge both cable TV
and OTA on a single coax cable to TVs and recorders (e.g., DVRs and
computers)?
Thank you in advance.
post #8733 of 9089
Cable = No. Satellite = maybe
post #8734 of 9089
Ah, so I will have to get two different coax cables for antenna and other for cable TV.
post #8735 of 9089
Yes, absolutely.
post #8736 of 9089
Originally Posted by ProjectSHO89 View Post
Yes, absolutely.
post #8737 of 9089
I have satellite, but won't the cable company install its own cable? So you will only be responsible for the OTA cable.
Will you be purchasing an OTA DVR?
That is one advantage I enjoy with DirecTV and its AM-21 OTA tuner: it converts their DVR into accepting and recording the OTA channels, too.
post #8738 of 9089
Ah, so they won't remove the old coax cables from the previous house owner who used Dish service? I already have an old OTA DVR (DTV Pal DVR).
post #8739 of 9089
I will let others respond about the reuse of existing cabling issue.
Does the DISH DTV PAL DVR continue to work without an existing DISH service contract?
post #8740 of 9089
Dish DTV Pal DVR is ONLY for OTA. Nothing else. Not cable TV, not Dish service, not DirecTV, etc.
post #8741 of 9089
Normally, cable providers will reuse existing wiring if present. If no wiring is present or the wiring is already in use, they will usually do a half-assed terrible job of running wires around the outside of the house and punching through walls where service is desired. If you want 2 separate runs to all rooms without ugly wires running around outside, you should run it yourself, or hire someone other than the cable company to do it. Do 2 runs from each room you want service to a central wiring area, either in a closet or in an easily-accessible portion of the attic, connected to 2 splitters. Connect the antenna to one, and do a run from the other to wherever the cable enters the home.
post #8742 of 9089
Ugh great.
I forgot to mention that the current coax setup only works with one room for OTA: Family room. Other rooms couldn't seem to get OTA antenna feed from the attic. Previous owner said Dish did work. I don't know if the coax setup is messed up somewhere.
post #8743 of 9089
I just bought a Samsung 64e8000 (great tv) but the digital search for OTA channels only produced 3 (52,53 and 54). All 3 come in perfectly but my last tv had all of the channels. I have a good antenna and great sight to Mt. Wilson. Why only 3?
post #8744 of 9089
Lose cables? Weaker tuner? What was your previous TV? I assume it is the same coax cables, antenna, etc.?
post #8745 of 9089
Everything the same. I had a Mits DLP 65". The 3 channels come in perfectly.
post #8746 of 9089
Before scanning, you have to select AIR....instead of CABLE. Maybe?????
post #8747 of 9089
yep. I did that. they have 4 choices. digital air, air, cable and cable air I picked digital air and air and it found only 3.
post #8748 of 9089
Hello.
computers)?
Some DirecTV SAT systems overlap with the TV Band....and some don't,
but you'll have to get someone else to provide detailed particulars....
Dishnet uses Multiswitches either built into Dish mounted LNB's....or external.
In the latest, "PLUS" variant, the SAT channels for both polarizations
are multiplexed onto a SINGLE cable to each SAT Receiver, eliminating
the old requirement of TWO cables per drop.
Since Dishnet's SAT channels do NOT overlap the TV Band, they can
readily be Diplexed together with TV/SAT Diplexers...IF JUST ONE DROP.
If more than one Drop is needed, a Dishnet "Super Home Node"
(e.g Eagle Aspen SHN-42) Amplifies and then splits the OTA (or Cable)
signals for distribution to each Drop.
Dishnet also provides the ability to distribute the "TV2" Analog UHF
signal from the DVR to any conventional TV Receiver. The other
SHN-42 input is for redistribution of the "TV2" UHF Channel.
See fol. post where I answered this question earlier (see links to diagrams):
http://www.avsforum.com/avs-vb/showt...php?p=21560672
You need to register with Dishnet to see their Support pages....
post #8749 of 9089
Can you connect another OTA DTV Tuner (e.g. CECB Coupon Box or your
old DTV) to verify that the OTA Coax is still putting out a good signal???
FYI: Samsung Support website shows a new firmware release, dtg 15Mar2012.
Did you connect HDTV to internet for update????
Perhaps you need to call Samsung Tech support....it might be a bad tuner....
post #8750 of 9089
thanks for the help. I will try a new cable from my antenna. Tried talking to samsung tech support. After 5 minutes of explaining my problem, they asked me if I had an antenna! LOL. Not much support.
post #8751 of 9089
Very strange. There is no OTA 53 either virtual or real RF. If it's not an operator error than your Samsung is defective. Can you actually identify the programs you are seeing on 52, 53, 54, by station ID?
post #8752 of 9089
Has anyone in L.A. ever gotten reception of KERO RF 10 virtual 23 from Bakersfield?
post #8753 of 9089
Maybe they make systems "idiot-proof" now, but it used to be possible for an OTA antenna to get hooked to the CATV line and then spew those channels out to interfere with the OTA signals. This what an illegal CATV tap adjacent east (20'-30' from my OTA antenna) did in 1983 to Ch 4 http://www.qsl.net/wa5iyx/images/833311.jpg (with local KMOL-4 off air - it was horrendous zero-beat CCI when they were on). CATV tech investigated and changed the 4-port CATV backyard pedestal to 3-ports - no Texas theft-of-service statutes yet then for them to prosecute the party. This was probably radiation from the 300-ohm twin-lead that they ran (w/o balun ?) from the CATV coax to the TV set.
post #8754 of 9089
OK, 1966 QST vs CQ. They each ran those types of articles in Aprils back then
post #8755 of 9089
No. I have never received it, and I have never heard of anyone else who has. I believe the mountains (Santa Susanna and San Gabriel) immediately north of L.A. form a barrier to the north. It would likely be impossible for a signal, especially an RF signal on UHF to get through.
post #8756 of 9089
That would be an impossibility in the LA Basin. Antelope Valley would be a huge maybe but riding more toward never. KERO sends the bulk of their signal West and North from Breckenridge across the Southern San Joaquin Valley floor and it's not exactly putting out that much power behind it as it is.
KERO and KBAK out of Bakersfield were piped in on cable systems in the Antelope Valley. A least they were back in the late 70's when I lived there. I'm not sure that practice is still employed nowadays.
post #8757 of 9089
Drats. Attic doesn't improve. Some channels are still missing like on the ground level's kitchen. I guess OTA is no good. We will be taking it down and returning it to get satellite/cable service.
Updates! My father/pa/dad and I finally worked on this RCA ANT-751 antenna in the attic, one more time today, since its return date to Fry's Electronics is a few days away and today was the only good day to retry it.
We also worked on trying to get the multiple house rooms as well. We found the Dish's multiswitch and replaced it with an old splitter. We also finally got all the rooms's coax outlets working. We noticed the cables setups are messy and confusing in the attic. It seems like Dish or someone cut the old coax cables? We also found the best spot in the attic and hopefully, the channels will stay this way even though there are missing ones. We also brought in an old portable CRT TV, with its power AC, with a few years old Zeinth DTT900 converter box (got one with a government coupon), I ran channel scans and noted the "stable" channels:
Old portable CRT TV + Zeinth DTT900 DTV converter box:
57-83 channels found (did two scans): KCBS2, KNBC4, KTLA5, KABC7, KCAL9, KSCI18, 22, KCET28, ION30, 31, 34, 46, 52, 56, 57, KLCS58 (soso), 62, and 63.
Portable DTV (ATSC; Digital Prism):
88 channels found (wow): KCBS2, KNBC4, KTLA5, KABC7, KCAL9, 22, 28, ION30, 31, 34, 46, 52, 56, 57 (soso), 58, and 62.
Note that I gave the channel the station code/ID names for the ones we care for.
As you can see both of them are missing the ones I care for: KTTV11 (I watch FOX's shows a lot and sports sometimes), KCOP13 (I used to watch it for its Star Trek, but don't care any more), and KOCE50 (rarely though).
I find it amusing with a Terk FDTV1a Digital Pro antenna (vertical flat one), that my father/da/pa bought from Best Buy which I did not approve [sighs], worked for these missing stations: KCAL9 and KTTV11. The catch is that this antenna has to be on the middle the kitchen floor (no furnitures yet!) facing the garage's wall with an old central air condition (AC) unit throuhg the big window doors. LOL! That makes no sense though! There's wall! Maybe reflective from the wall and/or AC? Of course, this antenna is useless for every channels for its weakness (duh, we knew that).
I wonder if there something else to try to get KTTV11 and KCOP13. Then, I really don't need cable/satellite service! I do need to test the channels again to be sure they are really that stable. As you noticed, some scans don't get all or missed them. I even tried forcing them like 11-1, but no signals.
post #8758 of 9089
...I wonder if there something else to try to get KTTV11 and KCOP13. Then, I really don't need cable/satellite service! I do need to test the channels again to be sure they are really that stable. As you noticed, some scans don't get all or missed them. I even tried forcing them like 11-1, but no signals.
You will probably get much better performance on VHF by using a specialized high band VHF-only antenna like the Winegard YA-1713. It has a lot more VHF elements, than an all-band antenna, and is specialized for chs. 7-13 only. You could then add a UHF antenna for the other channels.
post #8759 of 9089
Is it possible to put it in indoor like in the attic since my folks hate the roof top attic idea. It looks huge.
post #8760 of 9089
Yes, it is very large- 99 7/8 " long, but it comes folded up, with the main boom folded in the middle. Winegard gives the carton dimensions as only 6.25" x 6.25" x 59", so you can easily take it upstairs in the attic before unfolding it. Just make sure first that you have a suitably large place in the attic for the antenna once it is deployed.
