AVS › AVS Forum › Display Devices › Screens › DIY Screen Frame
DIY Screen Frame
post #1 of 3
Has anyone painted their DIY screen frame using flat black paint or are you using black felt?
Which are you using and why?
post #2 of 3
<font face="Verdana, Arial" size="2">Originally posted by pcdoctor:
</font>
Check out http://www.geocities.com/sstieferman
I chose a dark stain and am very pleased with it. Personally, if I were to do it again - I would wrap the frame in a black velvet first and then mount the screen to it.
I would not suggest paint because of possible flaking - you know - black dandruff! As for the felt, Velvet has a tighter weave and backing material over felt. When I've worked with felt in the past, it is see through when light reflects off of the material below it.
post #3 of 3
Thank you so much!
I appreciate the info.
Glenise
  Back to Forum: Screens
This thread is locked
