AVS › AVS Forum › Display Devices › Screens › Dalite Damat Imager price?
post #1 of 2
Hi all,
My local dealer has a store display a wall mounted 100 inches 4:3 screen for $600. This includes the black metal frame around the border of screen. Is it a good buy? Is this Imager 1.1 gain? I'm not sure. I'm planning to get the Infocus LP350 or NEC VT540. Thanks for any help.
post #2 of 2
tvuong,
First, let's answer your question about the gain of the screen. The Imager can be made with gains from 0.8 up to 1.5. Exactly what gain the screen is that you are contemplating buying needs to be answered by the dealer. They would have specified it when they ordered it from us. As for the price of the unit, you are getting a great deal. The retail cost of that screen is $855 with the 1.1 gain fabric. If you can get it for $600 then you should move quickly.
Good luck,
Blake
  Back to Forum: Screens
This thread is locked
