AVS › AVS Forum › Display Devices › Screens › Limit Switch
Limit Switch
post #1 of 5
Hope this isn't too dumb a question.
I have a 100" Stewart screen circa 1991. Is there a limit switch that sets how far the screen comes down??? If so, where is it, and how do you adjust it?
Thanks in advance,
Bob Smith
post #2 of 5
Hi Bob, did you look up on the left hand side of the roll to see if there are any bolts white or yellow in colour? On my screen there are two, but its alot newer...
gordf
post #3 of 5
Gordf,
Thanks for the response. I'm not at home right now to look, but I don't remember them. I do remember there is a red LED on the left and also a grommet through which I am hoping there might be an adjustment screw or something to access. Will check on this when I get home tonight.
Bob
post #4 of 5
Dear Bob,
As Gordf mentioned the limit switches are on the left hand side of the screen roller tube. Since your unit was manufactured in 1991 the limit switch are differnet that the ones we make today.
For best results call Stewart Filmscreen toll free at 1 800 762-4999 and ask for Scott Kimber in customer support. He can walk you throught the simple adjustment in a matter of a few minutes.
Don
post #5 of 5
Wow, an answer from the master himself! Thanks, I'll give a call on Monday and try and have the model number ready.
Bob
  Back to Forum: Screens
This thread is locked
