Originally Posted by dishrich
Except back then, it was ONLY for expanded basic subs; now they are finishing this up for ALL (limited) basic subs - so that there will be NO analog left whatsover.
(If you mean for the fact this IS happening - yes, ALL the (last) remaining analog goes bye-bye on 6/5.
Hopefully, more HD will be following very soon...)
All limited basic channels (both SD & HD) WILL remain available in clear QAM - which is stated quite plainly on the notices that just went out. But, that could change later...see next post.
Yes, however, you may need to rescan your plasma, if they move QAM's around, which is very possible.
HOWEVER...I will tell you that Comcast IS in the process of requesting a waiver from the FCC, to allow them to encrypt EVERYTHING, including the clear QAM (HD) local channels. But, they are also coming out with an HD DTA, which will allow you to get the HD locals back. No word on if subs can get these (HD) DTA's as part of "3 free DTA's" limited subs already get...but I would be willing to bet they WILL be.
If you really mean you're using a DTA, then yes, this setup will NOT change after the analog shut-off.
Dishrich, you were right with your second to the last statement. In Springfield with Comcast I have an HDTV with (via a splitter) a direct connection from the wall Comcast outlet to my HDTV and a connection from the wall Comcast outlet to my Comcast digital receiver to a Panasonic VHS/DVD recorder and then to the Panasonic HDTV with a QAM tuner. Sometime after June 5 I noticed that I could not get any of the channels from 2 through 23 anymore with the direct wall connection to the HDTV except the HD channels such 3-1 (CBS), 12-1(PBS), 20-1(ABC), 55-1 (Fox), 78-1(WGN) and so on. When I went to channel 2 or 3, for example, there was a message on the screen to call Comcast. Now the screen is blank or has snow with no message. Obviously I can still get channels 2 through 23 with the Comcast digital receiver.
Will reprograming the channels for my TV allow me to get channels 2 through 23 from my direct wall outlet connection like I had previously?
Is there any chance of losing my HD channels from the direct wall connection?
Thanks for any advice.
