AVS › AVS Forum › Display Devices › Screens › How do I clean a rear projection screen??
post #1 of 6
I just bought an Electrohome Retro, which is just a big rear projection tv with an ECP-4100 crt projector inside. The screen is textured and seems to have a couple of stains on it, how can I clean this textured plastic screen? If I can't clean it effectively, where can I get a cheap/and/or better replacement? Are there any plastic architectual products that can be used as a screen?
Thanks, Paul.
post #2 of 6
Anyone? Come on there must be someone out there who knows something about rear projection screens?
Thanks, Paul.
post #3 of 6
Invite me over to see the GP projector. I'll take a look at it, and we should be able to come up with something other than spray 9 and steel wool.
goosystems.com
Ken Hotte
kbk@cyberfreak.dhs.org
post #4 of 6
All I ever used is water and a soft lint free cloth.
Don
post #5 of 6
The water and lint free cloth has had a try, as has a soft brush and mild warm soapy water. Whatever is on the screen, you can see that it is in the tiny grooves, and stubbornly attatched!
Thanks, Paul.
post #6 of 6
I solved my own problem, and in case anyone else has a rear projection screen with coffee, or tobacco tar, or some other noxious substance in the grooves of the screen, just use baking soda, hot water, and a soft tooth brush. It cleaned the stain, and seemed to polish the surface slightly.
Thanks, Paul.
  Back to Forum: Screens
This thread is locked
