AVS › AVS Forum › Display Devices › Screens › Screen height from ceiling
post #1 of 2
I've got a 106" diag HDTV format screen w/ Sony 1271Q--I'm looking for advice regarding the screen center height on wall (8'6") or top of screen distance from ceiling.
thanks,
Matt
post #2 of 2
Matt,
When using a 3 gun CRT typr projector, the relationship of the screen to the ceiling is based on the relationship between the projector and the mounting system (either floor or ceiling). It has to be an exact number which is listed in the installation guide.
You might want to post this question in the CRT PROJECTOR Forum here at AVS, if you don't have the manual. Someone with the manual can give you the specs.
CRT typr PJ's are not like single lens type PJ's where the mounting is extremly flexible. If you are off as much as 1/2 an inch, you can mess up the instllation.
Lee
  Back to Forum: Screens
This thread is locked
