AVS › AVS Forum › Display Devices › Screens › New be need help with screen
post #1 of 2
I bought a used projector that I am putting in a room I built the sizes are below and the layout.
http://www.programmergeek.com/Pics/Basement2/index.htm
Is this the right size screen for the room or is it to big? I would perfer a roll up type, any sugestions on brands/places to buy. I plan to replace the projector in a year or two so I am more worried about room fit.
http://www.programmergeek.com/Pics/Basement2/layout.gif<FONT COLOR="Blue">Text</FONT c>
[This message has been edited by programmergeek (edited 07-24-2001).]
post #2 of 2
Your question would be better answerd if you discrib more about your projector then the room for exemple:
Lummenes, resolution throw distence etc... it is a small screen and you might be able to get a larger 16.9 Rick
also try to contact Stweart Screens or Da-lite.
  Back to Forum: Screens
This thread is locked
