AVS › AVS Forum › Display Devices › Screens › triggering a screen
triggering a screen
post #1 of 7
Need help. I have a VUTEC screen and just bought an accessory adapter for 12c volt trigerring. For the life of me how do I get the screen to turn on when the projector is switched on. My projector doesnt have a 12 volt out so please hlp
James
post #2 of 7
I am assuming you already have it connected to your screen? You need something with a 12v output to trigger the screen. Does your surround processor or receiver have such an output?
Never become so involved with something that it blinds you.
post #3 of 7
Nothing has the 12 volt trigger in my system thats my problem
post #4 of 7
I am sure it would be possible to send a 12v single manually to the screen but that defeats the purpose. You bought the interface so that you would have remote control right? You are going to have to buy either a new processor, receiver, projector or send the interface back. It probably would be cheaper to just take it back to the dealer and continuing to use the manual switch because without a remote control device that outputs a 12v trigger it is just going in circles. Are you planning on upgrading any items in your system? Maybe now's the time to add dolby prologic II or dolby ex or something and get a 12v trigger in the deal.
[This message has been edited by Bulldogger (edited 07-23-2001).]
post #5 of 7
This thread tells you how to add a 12vdc trigger to any projector. Worked for me...
http://www.avsforum.com/ubb/Forum10/HTML/002953.html
Randy
G20/CI/GrayHawk
post #6 of 7
Guys I appreciate your advice but how do I connect this thing ? It doesnt seem to have anything about 12v on it written !
post #7 of 7
12VDC trigger via a "wall wart" or transformer plugged into the back of your receiver or a cheap receiver that turns on via IR.
Dave
Watch HDTV!!! Nothing else comes close!
  Back to Forum: Screens
This thread is locked
