AVS › AVS Forum › Display Devices › Screens › DIY screen construction illustrated for newbies
post #1 of 3
i'm not claiming this is the best way, this is just the way i did it and it seemed to work out well.
materials:
blackout fabric-purchased at any fabric store
several 1" x 2" x 8' ( or 12' depending how wide your screen is) pieces of wood
...image isn't posting properly.
if someone else can put this up, drop me an e-mail and i'll send you the jpg
[This message has been edited by ckolchak (edited 08-01-2001).]
post #2 of 3
If you need someone to host the image, I can do that for you. If you have it on the web, but cannot get into the AVS forum, you may not be using the UBB code correctly.
To include an image, you need to do this:
[IMG] http://www.geocities.com/vonhofs/theater/latest_pic.jpg [/IMG]
Remove all the spaces, and you get:
Scott Vonhof
Scott's Site: DIY Speakers and Theater
[This message has been edited by SVonhof (edited 08-01-2001).]
post #3 of 3
Scott,
i was using Auction Watch to host, but i think they're starting to charge, that may be the problem. if its ok, i'll just send it to you and if you can put it up here whenever you get a chance, id appreciate it
thnx
ck
  Back to Forum: Screens
This thread is locked
