AVS › AVS Forum › Display Devices › Screens › What screen do you recommend for the Sony 1272Q?
post #1 of 5
This is my first post on this forum and look forward to the wealth of knowledge I might gain through the users...so Thanks in advance!!!
Just wondering what type of 16X9 screen you guys would suggest using with the Sony 1272Q?
Thanks again,
Brian E. Kiser
post #2 of 5
With a 7" CRT unit I would go no larger than 80"x45" if you plan to use a 16:9 screen. I use this screen size with my NEC 7" CRT projector and it gives a nice bright and sharp picture. Also, stick with a low gain (1.3 gain)screen material for better color uniformity across the entire screen.
The Imaging Science Foundation suggests using a 72"wide screen size with a 7" CRT projector for the best possible image.
DMan
The Academy Home Theater
post #3 of 5
I use a 100" Draper Cineperm 1.3 wall mounted screen. It's 4:3 though.
The picture is fantastic! Be sure you get a line doubler!! DVDO V2 works great!!
[This message has been edited by Samshort (edited 07-20-2001).]
post #4 of 5
Sam and I essentially are using the same screen size since both of our screens are 80" wide.
DMan
post #5 of 5
I am using a Stewart 2.5 gain 96x54 screen with my 1272Q. I am driving this with a Faroudja 2200 at 600p. The image does suffer slightly from hotspotting because of the very high gain, but the image is plenty bright and sharp enough with my setup, and I really wanted the larger screen.
I agree with Brian and Darren, by the way. The ideal setup for this projector (as far as image quality) is definately a lower gain, smaller screen. My solution was to me a way to get "almost as good" image quality on a larger screen.
Buddy Yaussy
My HT Page
  Back to Forum: Screens
This thread is locked
