AVS › AVS Forum › Display Devices › Screens › GrayHawk gain question
post #1 of 6
My GrayHawk screen should be in the truck on its way to VA...I'm getting excited to get it. http://www.avsforum.com/ubb/smile.gif
One question, I thought the GrayHawk gain was .85, but the Stewart web site lists the gain as .95. Is that right?
Ben
[This message has been edited by Ben (edited 03-07-2001).]
post #2 of 6
The gain for the regular screen is .85. They increased the gain to .95 for the perforated sceen because you lose some gain due to the holes. If you have a micro-perf then the gain is going to be higher. If you do not it will be .85
post #3 of 6
Ben,
Can you please email me you findings when you get your screen set up? I live in Sterling also and I am debating on which screen to get. Let me know what you think.
TIA
post #4 of 6
OK, if I am planning to use a Grayhawk, and a perforated screen, do I need to deduct any brightness for the perforations, or does .95 consider that already??
<scratching head> ??
-- Cain
post #5 of 6
Usual perf loss is said to be 10%.Thus perceived brightness is same(.85 approx for both.)
Ron
"Your priorities will be different-its the weighting that counts!"
post #6 of 6
The rated gain of the non-perfed screen is indeed .85 for the Grayhawk. However, in testing they have found that it is actually closer to .90+. Stewart quotes conservative gains so that if it happens to be more you will get a bonus. Some other companies quote higher than true gains for their screens to hype them up more. Another reason Stewart is the best!
Jason Turk
AV Science, Inc.
http://www.avscience.com
716-454-1460 ext.204
Jason@avscience.com
  Back to Forum: Screens
This thread is locked
