AVS › AVS Forum › Display Devices › Screens › Screens versus wall???
post #1 of 2
Newbe question
Does a screen such as a Daylite model B really produce that much better picture than just shooting on a white wall??? I am trying to decide if it is worth spending a couple hundred or so on a screen that has a 1.3 gain with a projector that has 850 lumens?? The picture on the wall is surprisenly good . So I am trying to decide if it is worth the money for a screen. If the screen produces a picture that is even 10 or 15 % better than on the wall it would be worth it to me?
Any thoughts on this or advice...thanks!
dplemmons
post #2 of 2
You might want to contact a Da-Lite dealer and have them send you a pack of samples. When I was deciding, I taped all the samples on the wall and then watched different kinds of material. For me, the lower gain screens (1.0-1.5) weren't significantly different than the white wall. My wall has a slight orange peel texture that I would have sanded down if I wasn't purchasing a screen.
Follow the "screen tests" link in my signature or better yet, get samples and decide for yourself.
Tom L.
NEC LT150 FAQ
My stuff, pictures, HTPC, and screen tests
[This message has been edited by tlastrange (edited 09-03-2001).]
  Back to Forum: Screens
This thread is locked
