AVS › AVS Forum › Display Devices › Screens › Interesting screen...
post #1 of 4
I was at my local hardware store picking up some lumber for my "screen" frame. Anyway, I was going to buy some tileboard so that I could align my projector to the screen. As I was looking around I ran across some white formica 4x8 sheets. I thought it may make an excellent screen yet affordable screen. How about gluing it to say a 1/4 or 1/2 plywood for backing? It would offer a pretty smooth, yet minimal texutre and would be extremely easy to clean! Anyone think this is a crazy? I wonder how my lt150 would work with it. I keep reading that the high power screens are great as long as the unit is not ceiling mounted. This might be a cheap and easy project. The price was around $40.
[This message has been edited by AfroCreame (edited 10-08-2001).]
post #2 of 4
AfroCreame,
I've been thinking the same thing for a while now but already bought a Da-Lite screen. Keep in mind that you can order 5' x 10' sheets as well and typically in Canada they cost about CDN$70. If your wall was smooth you could glue it directly on without having to use a plywood backing. I hope you try this because I would love to know how it works.
Rick
post #3 of 4
The (theoretical) problem with formica is that it’s TOO reflective. This can cause hot spotting in the image. If you do choose to give this a try, please let us know, OK?
Roberts Family Theater
post #4 of 4
  Back to Forum: Screens
This thread is locked
