Mr.Wiggles,
And not reading someone's post is just as dangerous.
Ever see this before? It was in my second post. Does it ask for higher bit depth INPUT sources? No. Does it suggest higher than 10-bit data (or output) paths? Yes.
So all this disagreement was caused by *me* not being clear on my first post (the last one you read) about using more than 10 bits in the data path, not the input source? Geesh.
Tom,
It is great to hear that this projector is not using a 10-bit data path. Since you mentioned 10-bits per channel, without mentioning a larger data path, in your first post, I incorrectly jumped to the over/underflow problems. Sorry. It seems that JVC's engineers agree that over/underflow is a concern and have expanded the data path beyond 10-bits to accomodate these problems. Excellent! When can I see one in the local cineplex?
Huck
| <font face="Verdana, Arial" size="2">The current crop of movies being shown on DLP Cinema screens is stored as 10 bit 4:2:2. Using 10 bits in the output path would leave no space for error terms. Using a 14-bit output path allows gamma correction and color space conversion to have some over/underflow space and should allow smoother color gradients and better black level detail.</font> |
Tom,
Huck
