dila settings
post #1 of 3
What's the difference between ST clamping and bpclamping? I dont think i see a difference? How can one illustrate the effect of this setting?
post #2 of 3
Good question. The instructions book did not explain, but suggested that it is not so important, if you do not have complaints in the setup.
post #3 of 3
Actually, it does explain it.
Quote: "if with some PCs or workstations the screen becomes unstable such as being too dark or too bright, try to switch to ST."
My take is on that is leave it alone unless you have that scenario.
Chris
This thread is locked
