AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Sanyo Aspect Ratio Control?
post #1 of 3
Hi All,
Anyone have any experience with a Sanyo XP21 on a 16:9 screen? Obviously PS DVD 480P and HD 1080i will be shown in 16:9, but how about 480i images? Is there a mode that will fit a 4:3 image inside the 16:9 image? Will there be bars on the side or will it stretch it or user selectable? Sanyo's site mentions a 16:9 mode but little or no additional information. Thanks,
Steve
post #2 of 3
I believe the 16:9 mode it refers to is just the anamorphic squeeze on enahnced material (ie. better display of a 16:9 image, not what you are asking about, which is framing of the 4:3)
I will try to look at it tonight though for you to find out more.
DG
post #3 of 3
If you have set-up the 21N in the widescreen mode and are projecting on a physical 16:9 format screen you cannot then present a boxed in 4:3 image on that screen without an external scaler like the qscan or Iscan pro. The 21n has a mode that will squish the 4:3 image to fit. It attempts some trickery to keep the center of the image frame undistorted while stretching the edges. You should at least use the Iscan pro...
This thread is locked
