AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Skinny "Digital" 5BNC cables vs RG6
post #1 of 3
I am ordering new cables for my expected video processor and would like a small bit of advice. I have a run of 25 ft and can either go with the skinny digital cables or the fat RG 6.
In both cases these would be Canare with 75ohm connectors.
I am planning to use a Rock and DILA.
Does anyone have an opinion? My guess is that at 25 ft either way is OK.
thanks.
ham
post #2 of 3
I have a similar set up , but utilize "skinny" cabling for the long run to the rock & then something more substantial in the "post" processing stage. Does your set up allow for the processor to be closer to the projector? Just a thought, Mark
post #3 of 3
Ham,
Thumper has done many installs using shielded CAT5E ethernet cable with HD-15 connectors on the ends. Yes you read that correctly
He has done them at up to 50 feet at SXGA resolution with very very little ghosting.
The 10pF/foot of the ethernet cable helps to make up for any impedance mismatch that might exist.
Good luck,
-Mr. Wigggles
The Mothership is now boarding.
This thread is locked
