RGBHV Remote Switch
post #1 of 2
Can anyone recommend a remote-controlled (infrared or PC-keyboard) RGBHV switch with at least four inputs? I'm looking for something under $400 and did not think this would be this hard to find.
post #2 of 2
Try Linksys KVM models. I have never used them but they look like a good contenders.
They will switch your keyboard and mouse as well.
The HTPC forum will be able to give you the best advice on this.
-Mr. Wigggles
The Mothership is now boarding.
This thread is locked
