Originally Posted by sammyYK
Does anyone get HD/SD KION near Monterey High School? At the moment I have tried the old standby indoor antennas (one of those flexable T-shaped double wires) and the single wire taken from my stereo (5-6 ft long I think). To my surprise signal strength hovers around 70% for KCAH, KSBW, and KCBA. Occational dropouts but I suspect a better antenna might help that. But there is no signal at all for CBS. Antennaweb org does not even show KION as available except for the usual analog one. I assume they both use the same tower.
KION broadcasts from a different tower than all the other locals. The KION tower is southeast from Monterey. The others broadcast from a tower which is to the northeast.
For more info on local reception, there are a couple of posts in this thread which may help. In particular you may want to take a look at my post:
http://www.avsforum.com/avs-vb/showt...&&#post8314481
I'm next to Laguna Seca but a lot of the info may apply to your location as well...
