AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Outdoor remote usage - Can I use IR?
post #1 of 3
I'm looking for a remote that I can use outdoors for controlling volume and cd of my setup (which is inside). Is it possible to use an IR remote, assuming the deck area may be 25 ft from the house and it gets a fair amount of sun? Seems that most universal remotes are IR, and very few use RF. So, can I use IR directly by mounting an IR receiver in a window, or do I need some kind of RF extender. Can someone recommend a good RF extender? TIA
- HB
post #2 of 3
Radio Shack sells them foir about $39.00 or less. THey work really great.
post #3 of 3
The trick is in the receiver (sensor). I had one on the deck of my previous house - it was a Xantech, designed to be mounted outside, that rejected sunlight etc. HNick
  Back to Forum: Remote Control Area
This thread is locked
